2 10w6 in sealed box??
Old Sep 28, 2002 | 12:40 PM
njoph85's Avatar
is it possible to hook 2 jl 10w6's in a sealed box to the 4th generation bose stereo system. will it sound as good as if i were to totally redo my system wiht new head unit and speakers
Old Sep 28, 2002 | 06:16 PM
BLack2k2MaX's Avatar
well it matters on the amp you use...you can hook it up but i really suggest changing over the head unit... i hooked the subs to the factory head unit... then changed to a aftermarket great difference in sound quality... i say go for a new head unit
Old Sep 28, 2002 | 07:54 PM
BeauBlanco's Avatar
I second that. Understand this, an aftermarket head has a high voltage output which dictates all the information that is sent to the amp. The adapter you will need to use w/ the factory head outputs diddly. You shoud look for an aftermarket head w/ a minimum output of 4 volts. Thats will get you good tight sound if you have a decent amplifier. Good luck!
James92SE
142
Jan 2, 2024 09:23 AM
mpbclutch33
Dec 26, 2015 11:11 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
The Wizard
24
Oct 1, 2015 08:47 PM
Sep 27, 2015 08:37 AM
