Sub Box Size?
Old Sep 29, 2002 | 06:55 PM
Nore474's Avatar
Sub Box Size?
I am about to build a box for my trunk. How big can the box be to fit into the maxima trunk? and I am considering MA audio for the subs and amp what do you guys thinik
Old Sep 29, 2002 | 07:37 PM
BLack2k2MaX's Avatar
the MA audio amp is good i got the 1286i i like it
Old Sep 29, 2002 | 09:28 PM
max'n out's Avatar
I'm not a big fan of ma audio personally...As for how big the box can be...Well pretty big. But you may want to consider going with the recomended specs.
Old Sep 30, 2002 | 09:08 PM
jmax
I recently installed a single Adire Brahma 10 inch for a test listen. I have heard more than a few dual 12 setups with less output, less low end, and well less accuracy. This is in an SQ sealed box, about 0.6 - 0.7 cubic feet before driver displacement.
Old Oct 1, 2002 | 05:03 PM
Nore474's Avatar
I am askin how big can the box be because I don't want to build a box then find out that it doesn't fit in the trunk!
Old Oct 1, 2002 | 08:12 PM
max'n out's Avatar
Around 6.0-7.0 cubes total I think I once heard somone ran in there.
Old Oct 1, 2002 | 11:17 PM
jmax
Sorry, I didn't intend to offend you by answering the question that should have been asked. If you can't stick a tape measure in and figure out how much and what kind of sub can fit, then you need the type of answer I provided. I think if you look at any review of the car, or a Nissan brochure, you will see a trunk volume listed. But what can fit in the trunk really depends on your creativity and your installers knowledge.
Old Oct 2, 2002 | 10:45 AM
Nore474's Avatar
alright sorry Jmax I didn't mean to right it like that lol
I'm going to go do that now thanks a lot
Old Oct 2, 2002 | 11:17 AM
jmax
Also consider the size of the open trunk. What I mean is how wide and tall of a box will fit through the opening without removeing the trunk lid. Or how large a box can slide in from behind the rear seat.
Old Oct 3, 2002 | 08:29 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
dont forget the trunk hinges! this is where i messed up, the trunk wouldnt close becauswe the hinmges lower when u close the trunk!, theres also little bars sticking out from the hinge, so watch for that too,
good luck
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
