what size
Old Oct 9, 2002 | 01:01 AM
krmaxima's Avatar
what size
is the rear speaker and what is a good brad for really cheap
thanks
Old Oct 9, 2002 | 01:09 AM
JPMax's Avatar
What's next!?..
They are all 6.5" speakers front and rear for the normal stereo. The Bose system also has 1" tweeters, I think.
I prefer Pioneer speakers if you're looking for decent speakers at low prices.
Anything cheaper will get you..blah..
Nismo's Avatar
non bose is 6 3/4 how cheap are you looking for?
Old Oct 9, 2002 | 11:39 AM
krmaxima's Avatar
well i have the stock system not bose so is it 6.5 ot 6.75??? well just wondering i was planing in spending no more then 200 dollars
Old Oct 9, 2002 | 11:47 AM
JPMax's Avatar
What's next!?..
The stock size is actually 6.75" but you aren't gonna find many speakers in that size. And the ones that are out there are pretty expensive.
Most 6.5" speakers should fit fine.
Old Oct 9, 2002 | 06:05 PM
krmaxima's Avatar
do i get 3 way speakers or what do i get for the rears i blew them out???
thanks
Old Oct 9, 2002 | 06:56 PM
JPMax's Avatar
What's next!?..
I'd check with www.crutchfield.com to get some ideas and model numbers. Prices are a bit high there, but they have good info.
since you blew out the stock ones I assume you play em LOUD.
You'll need one that can handle high wattage and good sound range.
(30mhz - 20khz) would be a good start.
Careful with the 3 way speakers, they tend to stick out and the stock grill may not fit over them.
Heres some other websites:
etronics.com gopcplus.com hypeaudio.com sounddomain.com
Old Oct 9, 2002 | 07:59 PM
apocnmbr1
depends...u running these off some amps?? or off the stock deck?? if running off amps, you can pretty much get whatever u want....but if you want to run it off the stock deck...i suggest to get some of the low end boston acoustics. If you get the fx6 boston's, they only need around 20 wattsrms to sound preety nice without distortion. And i would probably get the same for the fronts too. The speakers retail for around 120 a pair, but im sure u can find em cheaper somewhere else. As far as sound wise...the bostona are gonna be the clearest and the most life-like sound speaker for that price. Im an installer and i have heard many systems, and i know u can never go wrong with boston acoustic. Hope this helps. GL
Old Oct 10, 2002 | 11:53 AM
krmaxima's Avatar
well i dont understand is the front and rear the same speaker??? or r they different and what kind r they????
thanks
Old Oct 10, 2002 | 01:14 PM
JPMax's Avatar
What's next!?..
thanks
What do you mean by 'what kind'??
They are all the same size.
As far as 1-way, 2-way, or 3-way...
I haven't gotten around to replacing my stock ones yet so I have no idea. But I'm pretty sure they are all the same whatever it is.
Since your rears are blown, just pull one out and take a look.
If it's just a dome, it's 1 way. If it has a smaller speaker suspended above the main one, it's 2-way. I'm sure you can figure out the 3 way..
JP
Old Oct 10, 2002 | 01:27 PM
Redmax's Avatar
Redlinemax Owner
how much is cheap?? and pioneers suck!!!! no midbass at all
my .02
Miket2006
Mar 1, 2021 03:55 AM
RIPTIDER
Wheels/Tires
Jan 31, 2016 07:39 AM
knight_yyz
Nov 1, 2015 01:34 PM
