How to Tapp into a speaker wire?
Old Oct 16, 2002 | 12:56 PM
PoweredbyNissan
So when you guys tapp into a speaker wire, to convert it to RCA or plugin directly to the high level inputs on the amp, what gauge speaker wires do you use to tapp into the factory speaker wires? factory speaker wires are pretty skinny, like 24 or 22 gauge?? if you are running 300 watt system , does it matter what gauge wire you use to tapp into the factory speaker wires? the biggger the better??
Old Oct 16, 2002 | 11:46 PM
MIXXMAX's Avatar
Re: How to Tapp into a speaker wire?
If your running 300 watts or so, I would avoid using speaker level inputs. Your sound will not be as "clean" as compared to using RCA's. Furthermore, you may run into a problem of "noise" entering your system because of the speakers being used as the level inputs. Use the low level inputs (RCA) if you can.
Old Oct 17, 2002 | 09:29 AM
PoweredbyNissan
Re: Re: How to Tapp into a speaker wire?
Don't have RCA preout from the car......
Old Oct 17, 2002 | 04:42 PM
MIXXMAX's Avatar
Another suggestion you can try is an adapter they sell at Crutchfield.com. It's an adapter where you use your speaker outputs as a low level input which have RCA's (on the adapter). This adapter is useful for headunits that don't have the RCA's outputs.
Old Oct 17, 2002 | 06:51 PM
PoweredbyNissan
Nah, I rather just go directly into my amps' high level input. The adapter works the same way dont they? and i hear they create noise when the volume is high.
Old Oct 17, 2002 | 09:09 PM
Michael J.'s Avatar
PLEASE READ THIS
After having the Speaker Level ---> RCA Outs, and then buying a real deck (Kenwood Excelon 759) and using the RCA Outs. NEVER, EVER, do the speaker line imput. Your bass will sound sloppy and distorted. And your gains will have to be set to the max.
Take it form years of expirience, it is not worth the trouble.
If your located in CT, I can even help you out.
- Mike
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
