Would 1/2 cubic vented box be alot better then a 1 cubic normal one?
Old Nov 2, 2002 | 10:09 AM
doomtoo's Avatar
I kinda need the less space, but will it also be alot less bass?
Old Nov 2, 2002 | 10:22 AM
jmax
Re: Would 1/2 cubic vented box be alot better then a 1 cubic normal one?
You will need a really long port in a 1/2 cubic foot enclosure to tune low. The port volume may be significant enough to make the 1/2 cubic foot ported box larger than the 1 cubic foot sealed. I don't know if the port will be enough to compensate for the less efficient smaller box.
The overall diffence in box size between a 1/2 cubic foot sealed and a 1 cubic foot sealed is very little. Unless you use thinner wall materials, you will use more than half as much wood. So it won't be half as large a box, more like 60-80 % as large. Going ported may mean the overall box volume will be greater than the 1 cubic foot sealed. Oops, I said that twice.
Old Nov 2, 2002 | 10:34 AM
bahmax's Avatar
Firstly, a ported box usually needs to be larger than a sealed box for the same sub. The reason is as stated above, for a small ported box, you would need a really long port. I don't think you could fit a large enough port in a box that small. If you absolutely have to use a box that small, I would build a sealed box and then fill it with accoustic type filling to make it seem larger. Other options include getting subs that are designed for small box applications (IDQ etc.)
Brett
Miket2006
Mar 1, 2021 03:55 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
Sep 27, 2015 08:37 AM
Tmax78
Sep 25, 2015 09:07 PM
