who has a 15" installed in the spare tire well?
Im just thinking of ways to do a new install. I want a lightweight system that can still pound but keeping the weight to a minimum. My current setup is 2 tens in a big heavy bandpass box and thats a little hevy for me so I was thinking about just getting 1 LIGHT sub either 12 or a 15 and have it custom installed inside the spare tire place. Im not looking for anything specal, just flush mounted in there. anyone here have pics? There was a 5th gen I saw at Stillen day and he had 2 eclipse subs flush mounted in there, anyone know what shops would charge for something like that?
Where you will pay big on that type of install is sealing the spare well with fiberglass and pressure fitting a mounting board...no undoable but very expensive and not likely easy to remove if need be.
Originally posted by ny96max
15's are very sloppy.
Ant
Ant
eric
Originally posted by InfamousOrange
12's, 15's....i say take the average: get a 13.5. the new w7 comes in a 13.5 clarity and kaboom all in one nice package
15's can sound very nice. i'm pretty nismo240sx's system sounds killer. if i had the money and amps i'd go with a brahma 15". i don't have the money or the power so i went with a adire tempest 15" in the trunk floor.
Originally posted by loudmaxima
its not really deep enough to mount a 15 flush
Originally posted by victor
very true. well depends on the sub. i have mine about 3.5 inches above the trunk floor. i then raised the rest of the floor 4 inches, so i could put the amps and distribution blocks in the stealth too.
i think i used about half a 4x8 sheet of plywood and mdf combined. i used a little less than 2 gallons of fiberglass resin. and then i used some old sheets to get the mold, and then i finished it off with some fiberglass cloth. and a few pieces of rope for strength.
spend about 100 bucks on material. didn't think i'd end up spending so much, but that's what it came out to. really sturdy enclosure.
If you use more fabric and less resin it will be lighter, and stronger. I think the average mix is 50/50. Varies by fabric style and material. 2 gallons of resin seems to be a huge amount for a tire well. I was thinking more like 1.5 - 2 qts. But that's if a good quality wood is used for the frame and majority of the baffle. Of course it does depend on the total volume you need to surround in glass and resin. A 15 might take a gallon of resin if it needs a big box.
Also a 12 inch sub can do everything a ten can do with about another 1/2 octave of extension. Except that the 12 can do it with 2/3 as much effort / amp power. A 15 can do everything a 12 can do with another half octave or more extension. But the 15 will move almost twice as much air with the same amp. The idea that large subs are slow or inaccurate is an old wives tale. If you believe that you need to spend less time in the beauty parlor and more time listening to music.
I've got the double 10 in the wheel well setup, damn fine, but the extension isn't as good due to the distance from the trunk roof, still kicks a ear shattering ton, but I think I lose a lot more than other setups with the same subs and amps. Even with 1000 watts on the 2 subs, it's about as powerful as the same subs in my T-bird at 400 total watts. Sometimes you just have to take the chance and go with it, I may change subs, but I think I'll keep the glassed box intact.
Re: who has a 15" installed in the spare tire well?
Mine aren't as close to the rear wall as Carlos' subs, but it works all the same. The box is smaller than the old one, but not by much. I'm looking for a new sub sound anyway, something a little different for a change. Specialists here in town quoted me 1200 for the setup and I got it for less than half that elsewhere for everything.
Originally posted by max'n out
Lets not forget tuning plays a large role too.
A glass / BB box in the spare well will be less than $150 for materials. And that's with the best materials available for this sort of thing. Epoxy resin, kevlar and satin weave glass fabric, baltic birch, stainless screws and t-nuts. You could upgrade to carbon fabric for a little more money.
my enclosure was about 4.0 cubic feet without displacement, but you should be able to get away using a gallon if your going to do a flush mount. i had to raise my floor a bit. i'm still kinda new with fiberglass, also.
Originally posted by jmax
Yes, a little bit of eq'ing and the low end changes dramatically.
Oh yeah, she's a bigg'un. But I think she'll look like a little girl next to what I am going to br trying to do over the winter.
you care to share?
lol. that's straight.
pkfinn
09-13-2015 08:01 AM
dutch078
Wheels/Tires
08-03-2015 06:58 PM
