Pls advise...lights dimming even with cap & new Optima yellow top
Here's my setup for my 97SE:
New Optima yellow top battery-->4awg power wire-->Lightning Audio 1.0 farad Bolt Series capacitor - also connected to the (+)terminal of the cap are two 8awg power wires running to a RF400a4(50x4) & a RF500a2(500x1)
The 8awg ground wires from the amps are connected back to the (-)terminal of the cap & from there, a single 4awg ground is connected to the car's chassis.
Whenever I BUMP music with high bass content, my headlights dim. I thought the 1.0 farad cap (rated for 1000watts) & yellow top battery would solve this problem but it hasn't! What gives? I'm only running AT MOST 700watts RMS (BTW, the 500a2 is only pushing a single JL Audio 12w3 so the gains for this amp are all the way down.)
Could it possibly be a faulty cap?
Cap
Did you pre-charge the cap befor installing it? I have a 400a4 and a 800a2 with two fared and one battery...not a problem...with any car you will get some light dim because of the pull from the amps....might try adding another .5 fared or more....charged of course
Re: Cap
green light
the green light should come on while charging then go off after it is done charging....when there is no light on the indicator card the cap is fully charged...if the red light is on it means the cap is discharged.....so charge it until the green light goes off and then it will gbe fully charged with, at least thats how it is on the fosgate cards...just check your manual thats about all I can tell you
alternator
Originally posted by CalsonicSE
...and how do I do that?
05RLS2
Apr 14, 2016 11:49 AM
