Cooling fan for amp?
Old Nov 13, 2002 | 08:56 AM
1MAX2NV's Avatar
I'm plan on mounting my amp in the spare tire location with a plexiglass covering it. I need to find some sort of cooling fan that can actually move enough air to be effective. I need something that looks good and works good. Any ideas? Links? My local audio shop said those square type of fan from radio shack won't move enough air. Is that true?
Old Nov 13, 2002 | 10:10 AM
ny96max's Avatar
im using 2 CPU fans(12volt DC brushless), i belive they are 5 1/4" across all black. I used very small tabs of clear silicone on each corner to secure them down. You must use a relay though, or else you run the risk of buring up your remote line. since the install my sub amp has NEVER shut down due to overheating!
You can buy these at BestBuy for $10 each or at RadioShack for $15 each.
what kinda amp are these goin on?
Ant
Old Nov 13, 2002 | 10:22 AM
vabeachmax's Avatar
How would you wire them up with a relay?
-Tom
Old Nov 13, 2002 | 10:48 AM
ny96max's Avatar
RELAY:
85 = Ground (chasis ground)
30 = 12volt input (12volt constant power source, fuse block and or amp power line)
86 = input from radio (use the amp turn on lead off your radio for this, blue/white wire)
87 = output (this line will be your new remote turn on for the amp, as well as the power (+) for the fans)
hope that helps!
Ant
Old Nov 15, 2002 | 01:44 PM
1MAX2NV's Avatar
I forgot to check back on this thread...anyway it's the same old PG XS6600 I have in my car right now. I'm just relocating it.
Ant
Old Nov 16, 2002 | 03:51 PM
Bad97MaxSE's Avatar
Phoenix Gold amps come with them built in.
Old Nov 16, 2002 | 04:39 PM
max'n out's Avatar
Thats not enough in a sealed enviroment.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
