HELP!!!! How do you connect a FM Moulator to a 5th Gen Stock Stero???
Old Nov 21, 2002 | 01:05 PM
K Pazzo 6's Avatar
HELP!!!! How do you connect a FM Modulator to a 5th Gen Stock Stero???
I took the radio off & looked at the back of the radio & where I thought was the antenna wire all the way to the left...it didn't seem like it b/c it had 2 pins at the end of wire & my fm modulator doesn't take pins like that???
Old Nov 21, 2002 | 01:15 PM
maximadave's Avatar
detailerdaveb@gmail.com
Re: HELP!!!! How do you connect a FM Moulator to a 5th Gen Stock Stero???
You need to purchase 2 fm diversity antenna adapters which are available at most car audio shops or auto part stores. They are roughly $10.00 or so each.
Dave
Old Nov 21, 2002 | 04:48 PM
K Pazzo 6's Avatar
Re: Re: HELP!!!! How do you connect a FM Moulator to a 5th Gen Stock Stero???
Dave
thanks
Old Nov 22, 2002 | 05:15 PM
TonySoprano's Avatar
How easy is it to hook one up? Is it pretty easy taking out the BOSE system? I have a 2002 GLE and need to install one so I can hear my DVD's through the stereo.
Any information will be helpful! thanks!!
Old Nov 22, 2002 | 06:38 PM
K Pazzo 6's Avatar
first pull out the middle top vent by just pulling it out......then take the ashtray out & behind it there's 2 screws...then jerk the cover around the ashtray & shifter up & out....then you got 2 screws under the climate control...then 2 more screws all the way on top where the center vent was....& now you can pull the radio out
Old Nov 22, 2002 | 09:42 PM
maximadave's Avatar
http://www.discountmobilevideo.com/i...mmodulator.jpg
Old Nov 22, 2002 | 11:09 PM
Thanks for the help guys. I will check it out and install one soon!
Matt93SE
May 24, 2019 02:58 PM
melteye
May 16, 2016 12:02 AM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
