Subwoofer weight?
Old Nov 25, 2002 | 11:04 PM
MoDiddy's Avatar
Subwoofer weight?
Ok here goes....i want to get 2 twelves for my maxima...i want to know about how much 2 12's with an amp generally weighs...the reason i want to know is because i have my car lowered 2" with sprints...i got the back springs cut 1 coil for a more even drop...what do you guys think about the 2 12's?
thanks a lot,
MoDiddy
Old Nov 25, 2002 | 11:27 PM
WizzaMax's Avatar
What model subs and amp do you want...the weight differences can be marked from the weights of the magnet on the subs, make and dimensions of the box, and size of the amp.
Just for comparison, all my stuff weighs me down an estimated 100 lbs
Old Nov 26, 2002 | 12:55 AM
TL@altimas.net's Avatar
definately depends on the equipment.. there are 10lb subs & 70lb subs...
Old Nov 26, 2002 | 07:59 AM
MoDiddy's Avatar
WELL...I WAS LOOKING ON EBAY AND I THINK THE SUBS WERE AUDIOBAHN...NOT SURE OF THE MODEL..AND NOT SURE WHAT TYPE OF AMP I NEED..I DONT REALLY KNOW THAT MUCH ABOUT AUDIO EQUIPMENT...BTW THE SUBS WERE 1200 W EACH I BELIEVE.
Old Nov 26, 2002 | 09:39 AM
Shugarhi's Avatar
dual voice coils?
depends on how big those magnets are. also, take into consideration the weight of the box
Old Nov 26, 2002 | 12:39 PM
jmax
Originally posted by Shugarhi
dual voice coils?
Yep, the box can have as much variety in the weight as teh actual subs. When you order the subs the shipping package will likely have the weight on it somewhere. I just shipped two diamond audio macdaddy 12" subs and the weight of the box was 55.1 pounds. That was for both subs. So you could call 30 lb's average for a 12 and say it can vary by 29 to 200 lbs each.
Old Nov 26, 2002 | 12:54 PM
MoDiddy's Avatar
ok here is what the add says..maybe you can tell me how much it wieghs...2200 WATTS EACH SUB 1 BID=2 SUBS COME WITH 1 YEAR WARRANTY! NOT RETURNED, NOT REFURBISHED ~ BRAND NEW FACTORY SEALED! EACH SUB FEATURES 120oz Double Stacked Strontium Magnets Power Handling: 1100 watts R.M.S. Frequency Response: 20Hz - 500Hz Efficiency: 90dB PHAT 2" Multi-layer Foam Surround Stamped and Balanced Aluminum Cone 2.5" 4-Layer AVS Voice Coil Dual 4 Ohm Voice Coils 2 Ohm or 8 Ohm Operation Mounting Dimensions: Depth; 6 3/4" Hole; 10 7/8" Diameter; 12 1/2" Multi-connect Lug Lock Terminals shipping is 38.99 for both subs ups ground insured With hot looks and hot performance, this Audiobahn Flame Q subwoofer is an incredible addition to your sound system. The 12" 1206Q features dual 3-ohm voice coils (make sure your amp is stable down to 1-1/2 ohms before wiring in parallel), and double stacked, 120 oz. strontium magnets that handle all the power you want. A thick, 2" foam surround helps the cone maintain a linear travel for smooth, sleek, powerful low frequency reproduction, while the aluminum woofer cone sheds heat quickly for distortion-free bass. The unique "flame basket" design has the chrome look of a classic car — but the sound is thoroughly modern. For best results, use this sub in a ported enclosure. Key Features: aluminum woofer cone 2" foam surround dual 3-ohm voice coils (your amp must be stable down to 1-1/2 ohms if wiring in parallel) frequency response 20-500 Hz power range 50-1,100 watts RMS (550 watts per coil) peak power handling 2,200 watts sensitivity 96.4 dB top-mount depth 6-1/2" ported box volume: 2.585 cubic feet...BTW are audibahn subs any good...i think i heard they were...thanks alot
Old Nov 26, 2002 | 08:01 PM
jmax
They sell them at Crutchfield. They should be able to figeure out the shipping weight. Just go to the crutchfield web site and look up those subs. But 10-20 lbs here or there won't make or brake the suspension. If you have performance springs they should be stiffer than factory springs anyway.
user 11122324
42
Jul 18, 2022 03:35 PM
sliptap
Sep 30, 2015 05:57 AM
mpbclutch33
Sep 21, 2015 01:54 PM
