Poor Reception
Old Dec 9, 2002 | 06:53 AM
spta97's Avatar
Poor Reception - RESOLVED
I think I fixed my radio reception problem tonight! Originally I was using the ground wire in my wiring harness for the ground on my head unit (which I have done on every car I installed and never had a problem).
Anyway, I unplugged my antenna and my radio shut off. This lead me to believe it was getting a ground through the antenna. I wired the stereo ground to the chassis and the reception improved 100%. I don't know if this is an obvious solution but it wasn't for me. I think it may have something to do with the Bose system. Anyway, if you've tried the below steps and still have problems..try this .
I'm starting a new thread because the other one seems to have died.
I am having a radio reception problem with my Kenwood X859 radio. I do have the blue/white antenna turn on lead connected and I am using the diversity antenna adapter.
Just to be sure, I checked with Metra and it is the 40-NI10 that is required for the Nissan Diversity Antenna (NOT this one 40-NI20. I happen to have the Scosche NDA which is the same thing. I'm wondering if the Metra is better because my reception sucks.
I have done a search and not yielded the results I was looking for. Does anyone have similar problems or had similar problems and was able to fix them?
BTW, satellite is not an option since I only drive the car 1-2 days a week.
Thanks!
Old Dec 15, 2002 | 07:39 PM
spta97's Avatar
Updated....see above.
Old Dec 16, 2002 | 07:00 AM
Dustyroads's Avatar
Which year Maxima, my friend?? I'm still siffering from crappy reception! Did you have Bose or not?
Old Dec 16, 2002 | 07:18 AM
spta97's Avatar
Sorry, 2k3 - 5th Gen with Bose. Every owners manual for every stereo I've ever bought has said to ground the radio to bear metal. I never saw the need as I always used the ground in the factory wiring harness with no problem.
I could be smoking crack, but I think that this problem was because of the Bose (every other car I did was fine). However, I would apply both these fixes (connect power antenna wire even though there is no power antenna, ground stereo to metal chassis - not the harness) because it is the correct way to do it for any radio.
Let me know how it worked out!
Old Dec 18, 2002 | 01:49 PM
spta97's Avatar
Looks like I spoke too soon. The receiption did improve a lot but after taking it for a ride last night it's not 100%. I'm gonna call Kenwood to see what they have to say....they should be a big help
chisam14
Nov 6, 2018 08:56 PM
msellas
Sep 23, 2015 09:16 PM
