anyone run 0ga?
Old Dec 10, 2002 | 03:18 PM
makattack's Avatar
anyone run 0ga?
where the hell can you run it? Also I got the back seat off as well as the door sills but can't figure out how to run the rca's down the side....in between the doors is the seat belt pillar can't figure out how to remove it? Any help would be greatly appreciated.
Old Dec 10, 2002 | 03:49 PM
jmax
Run the RCA's down the middle. Remove the center console and rear seat. Just slide it down and through. The 0 gauge is not too difficult to get down the drivers side. If I remember correctly there are plastic panels that cover the factory wires. There should be enough room under this shroud for your 0 gauge. If not there is plenty of room outside of the shroud.
Old Dec 10, 2002 | 08:10 PM
mb1's Avatar
mb1
runt the power through the wheel well, after that, it should be simple ro run it under the stock plastic wire tube like jmax said. The seatbelt pillars pop off, they are held by clips. Just get in there with a screw driver and pull.
Old Dec 11, 2002 | 08:05 AM
makattack's Avatar
thanks
thanks very much guys.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
