Manual remote start pin 44?
Old Dec 11, 2002 | 03:24 PM
MAAXDOUT's Avatar
OK whats the latest using pin 44 gera sense wire for the remote start on the manual...Does it work??? any other ideas besides the clutch and key bypass and using this pin 44 ... the guy doing the install said any other info to make it safe would be appreciated.
Old Dec 12, 2002 | 05:52 AM
MAAXDOUT's Avatar
bump ... come on i know someone out here can answer this lol
Old Dec 12, 2002 | 07:14 AM
studman's Avatar
Here's the latest skinny, straight from the car's ECU...
Pin 44 IS the PNP switch (the switch that determines if the car is in gear or not). However, it only emits +5v when the car is in gear, not +12v like the ESM says. So, I've bought a 5v relay from Radio Shack, and am designing the circuit now. I should have full diagrams when it's finished and installed. The problem I've run into with the relay is that I need to design a way to power it ONLY when the Remote Start is active. The reason for this is that it would break the connection when you are in first, make the connection half-way between first and second, and break the connection when in second. This is "1 cycle" on the relay. The relay would cycle EVERY time you shift. And as you can imagine, the relay isn't gonna last very long at that rate.
So.... yes, pin 44 WILL work. But I haven't designed the circuit yet. I'm still researching the Viper 800 ESP with RS add-on, as well as the Viper 550 ESP (less options and wires available) to see how I can accomplish this. Stay tuned (will work on it during the holidays too).
Old Dec 13, 2002 | 06:10 PM
ThurzNite's Avatar
maybe call up MaximaDave who works @ Tweeter Audio and can give you some hints? Or send a PM to Pearl96max (i think that's his name) cuz he does many professional installs.
Jae
pjgreek
Sep 9, 2015 09:30 PM
beerman1378
Sep 8, 2015 02:19 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
