wiring the doors of a 4th gen...difficult?
Old Dec 15, 2002 | 10:35 AM
kingrukus's Avatar
no more maxima...
How difficult is it to run speaker wire through the doors to the front speakres from an amp in the rear of the car? Is it suggested? Or should one just stick with the oem wiring?
Phil
Old Dec 15, 2002 | 05:23 PM
MIXXMAX's Avatar
Re: wiring the doors of a 4th gen...difficult?
Phil
Not difficult at all. All you do is take the door panel off and feed the wiring thru the rubber grommet in between the door jamb. Then run the wiring underneath the door sills along the side of the car to the trunk, and your done!
Old Dec 15, 2002 | 05:46 PM
kingrukus's Avatar
no more maxima...
Re: Re: wiring the doors of a 4th gen...difficult?
Ok, I was just finding out, because I hear typically, regardless of the car, it is difficult to run wires to door speakers.
Old Dec 16, 2002 | 10:10 AM
1MAX2NV's Avatar
It's easier if you have one of those flexible claws and a can of WD40. I pushed the claws through first then grab the speaker wires. I sprayed ample amount of WD40 on the speaker wire's rubber insulation so they would slide easier.
Old Dec 17, 2002 | 08:08 PM
TylerBorg's Avatar
i did this and it worked out great... rewired my entire car and left the STOCK wiring in place for when i sell... front comps and rear coax with front amp in the trunk and rear coax off the h.u
might have some pics on my site, but i doubt it
http://www.sounddomain.com/id/swimmerty
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
