TV tuner antanna location??
Old Dec 16, 2002 | 10:39 PM
PhillyDonut's Avatar
For those guys with a 7"LCD with built in TV tuner, where do you wire the antanna? dose it get good reception? do you use any external antanna?
pd
Old Dec 16, 2002 | 11:06 PM
BigDogJonx's Avatar
Mine didnt have a built in antenna like inside the unit, it is an external antenna that has to be mounted on the inside of the rear window.
Dixit
Old Dec 17, 2002 | 06:40 AM
PCGuRu2K's Avatar
For my Kenwood 911 I wired the Antenna around the corners of the front windshield
Old Dec 17, 2002 | 11:03 PM
So how's the TV reception???? good, bad, or ok? does the antenna that you use connect to the unit through a coxial cable connection? I'm considering getting this TV tuner LCD that has an antenna built on it, the type that's like a redio antenna when you pull it out, but it also has a connection for an external antenna, but does not come with it.... thanks for any info.
pd
Old Dec 17, 2002 | 11:09 PM
BigDogJonx's Avatar
The reception on my car is crystal. I mean at times clearer than my normal TV at home. It is fairly good even if Im driving in areas where the signal is strong, but you still get that signal glitch that happens all the time which you cant get around.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
