AMP Ohm question
Old Dec 25, 2002 | 02:56 PM
Nismo3112's Avatar
Custom User Title
AMP Ohm question
Hey there,
Ok i have two 12" MTX single voice coil woofers rated at 250 rms and 500 max watts each, @ 4 ohm's,
My Pioneer amp (GM-X962) is rated:
125 watts RMS x 2 at 4 ohms
190 watts x 2 at 2 ohms
380 watts x 1 in bridged mode (760 max @ 4 ohm)
My questions are:
1. Can i run the "bridged" setup with 2 subs? and how would i wire the subs?
2. If not, can i run the 190 watts x 2 at 2 ohms even though the subs are rated at 4 ohm's?
Any help is apriciated, Thanks.
Old Dec 25, 2002 | 06:20 PM
mb1's Avatar
mb1
1. That will give you a 2ohm mono load, which the amp will probably not be able to sustain for a long time. Try it and see.
2. no
Old Dec 25, 2002 | 09:01 PM
GhostDog's Avatar
I would take that amp back, because it isn't 2ohm mono stable. You're stuck with 125x2 with that setup, which isn't going to hit with those subs.
-Tim
Old Dec 26, 2002 | 10:27 AM
Nismo3112's Avatar
Custom User Title
Well i brought back the Pioneer and got an Xtant A3001 amp which is 300 x 1 @ 2 ohm, and it sounds AWESOME.
Thanks for the help!
http://www.americantv.com/elec/e_det...&sku=077001471
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
popdedop
Sep 11, 2015 11:17 AM
