What's the best Sub setup between these 2 options?
Old Jan 21, 2003 | 12:24 PM
Ma><iManiac's Avatar
I have 2 Image Dynamics IDQ 12's in a sealed box. They are rated at 300W RMS a piece. I have them running in parallel off of a JBL BP600.1 amp, getting 150W a piece (4 Ohms). Would it sound better for me to run a single sub at 300W (the rated power for that sub) or 2 subs at 150W (Way below what the recommended RMS)? Also, how hard would it be for me to convert my existing sealed, 2 sub enclosure into a single encloseure? Wouldn't it just be a matter of sawing it down the middle and re-sealing the inside?
Old Jan 21, 2003 | 02:56 PM
Supa Lao's Avatar
With that amp, you are getting 300W @ 4 ohm and 600W @ 2 and 1 ohm. If you have that amp running in parallel, you should be giving the 2 subs 600W. Which is 300W per sub. You will be fine running the 2 12's w/ that amp. As for the box, I would reccomend them staying in there own chamber.
Old Jan 21, 2003 | 03:59 PM
jmax
Unless the subs are 2 ohm each, or dual 4 ohm. Cutting it down the middle would work. But your new enclosures would be smaller. The 3/4 inch walls that you insert in each half would decrease the internal volume a smidge.
Old Jan 21, 2003 | 05:33 PM
ThumpinMaxima's Avatar
if you have a sealed box with 2 subs in it...it should already be seperated into 2 chambers...mine is anyway...i dont know what kinda ghetto box u got rigged up
Old Jan 21, 2003 | 05:36 PM
Negative. It's an MTX dual sub box. One big space on the inside. Do you think that would keep the sound from being as tight as it could be?? I honestly don't know very much about this stuff, so please don't call me a moron, I'm just ignorant.
Old Jan 22, 2003 | 10:46 AM
I would think the bass would be tighter with 2 closed boxes...im not sure..im not an audio expert by no means either...
Old Jan 24, 2003 | 11:08 AM
Nore474's Avatar
I have a small sealed box for my 2-12's and I think its killing my subs they are not even close to thier full potential. My subs are suppose to set off car alarms. DO any of you guys know the best box to get for 2 12's I was think a badd pass or ported box
Old Jan 25, 2003 | 09:55 AM
Nore474's Avatar
here are the pics of my setup now notice the small Box
I wanna get a ported box what do you uys suggest?
Old Jan 25, 2003 | 10:08 AM
Jr'sMaxima's Avatar
Ported = much larger box!!!
Nore....just build your own box man, find the recommended box size for your sub and build it....and build it dual chambered. Building your own box is BY FAR cheaper, not TOO hard, just leave yourself a couple hours, and they are made with WAY MORE quality. Check out my homepage, that sub thats there, my IDMAX, the box that it is in I built, took about 3 hours from start to finish. Just use 3/4 MDF, some drywall screws to hold the box together while the liquid nails sets, thats the main thing here, letting that stuff set, and just put a bead around the inside of the box and spread it out and it forms a GREAT seal.
Trust me, building your own box is much more fun and better.
Old Jan 25, 2003 | 03:14 PM
Nore474's Avatar
I will try to build me a box
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
Redfox
Sep 28, 2015 10:41 AM
