Amp Installation With Bose
Old Jan 27, 2003 | 05:19 PM
Broaner's Avatar
2060lbs and falling...
I know about searching and all but im not finding the answers. I've heard that there are adapters for the bose HU to go into an amp RCA in. Thats cool but were do ya get em and how much are they. Also, since the HU has no remote turn on how do you trick the amp into turning on when the HU does. Thanx.
Old Jan 28, 2003 | 07:36 AM
phenryiv1's Avatar
Mod her. Ate her.
Read me.
Read me, too.
Those 2 threads should get you started. www.sounddomain.com sells adapters, as does PAC (though I was not aware of that until recently).
What year is your max?
I know that you said that yuo searched, but bot h of those threads were from the last 2 weeks.
This one was a freebie! J/K...
Old Jan 30, 2003 | 07:58 AM
gp1.2k's Avatar
ifinyawannaseethasite
Old Jan 30, 2003 | 11:05 AM
erty67's Avatar
Decal Specialist
some line level converters automatically sense the audio signal coming in when you turn the radio on.
Old Jan 30, 2003 | 12:08 PM
phenryiv1's Avatar
Mod her. Ate her.
Or you can tap off of the signal that the OEM system uses to turn the Bose on...it is the red wire on either rear speaker harness...
Old Jan 30, 2003 | 05:37 PM
erty67's Avatar
Decal Specialist
good point!
Old Jan 31, 2003 | 07:02 AM
phenryiv1's Avatar
Mod her. Ate her.
good point!
You know it!!
Seriously, if anyone wants to have more info on how to tap the turn-on signal from the stock Bose, PM or email me.
(help for search results- turn on turnon OEM amp )
Old Jan 31, 2003 | 07:19 AM
erty67's Avatar
Decal Specialist
You know it!!
ditto
Old Jan 31, 2003 | 09:47 AM
studman's Avatar
Here's a link to locate the appropriate adapter kits needed for your installation. This will give you the part numbers. Then you can order them directly from PAC or through your local PAC dealer (Circuit City, etc).
http://www.go2pac.com/oem1kits/oem1search.htm
Also, if you have a 2002, I've put up a wiring sheet at my website for the colors, etc.
http://maxima.theowensfamily.com/audio.html
Good luck. I've done it, so it can be done.
9aj9
Apr 5, 2020 12:11 AM
MaxLife17
Jun 27, 2019 01:37 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
