just bought this amp
Old Jan 28, 2003 | 08:33 PM
98maxsel's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...001895414&rd=1
is this going to be alright to use with my 2 eights? i will also keep stock bose setup with this..
Old Jan 28, 2003 | 09:50 PM
max'n out's Avatar
Re: just bought this amp
Why ask now that you have bought it? Now it's yours. Delete the other 5 post, and just use this one. Start by posting more info ,like what 8's you have and the spec. Complete and usefull info.
Old Jan 29, 2003 | 02:22 AM
98maxsel's Avatar
I have 2 pioneer eights enclosed in a custom box closed in plexiglass where you see the speakers. The specs not too sure about. I was told good eights can handle about 200 watts each. true?
Specifications for amp:
2 Channel Amplification
2 x 300 Watts Output
1 x 600 Watts Bridged Output
600 Watts Total Output
Polished Chrome Finish w/Plexiglass Panel
Remote Control Bass Boost (0-+1808 @ 60Hz)
Fully Adjustable Electronic Crossover Network
Soft Turn On/Off Circuit
2 Ohm Stereo Stable Bridgeable Into 4 Ohms
Moseft PWM Power Supplies
Variable Gain Control
Remote Turn On/Off
Hi/Low Level Inputs
Power On LED Indicator
LED Protection Indicator
Dimensions: 10.4"W x 2.6"H x 12"L
Weight: 8.4lb
any input appreciated since I don't know much about steros. How much to get this installed on my car with the stock bose setup?
Old Jan 29, 2003 | 06:15 AM
phenryiv1's Avatar
Mod her. Ate her.
Remote Turn On/Off
Hi/Low Level Inputs
Weight: 8.4lb
What impedence are the 8s? That makes a big difference.
I could have sold you a better amp than that one (though it would be used). You got what is normally thought of as a disposible amp- one that will do its thing for a while, but will eventually burn out and have to be replaced.
Old Jan 29, 2003 | 02:43 PM
max'n out's Avatar
I need the info on teh 8"s, could you tell me which ones they are at least.
Old Jan 31, 2003 | 03:53 AM
98maxsel's Avatar
sorry , i have no idea, i bought them off someone i work withj.... i know they work b/c i heard them in his car recently... he just said they were custom pioneers.
Old Jan 31, 2003 | 07:45 AM
phenryiv1's Avatar
Mod her. Ate her.
You need to unscrew one and pull it out of the box and we can tell you what to look for on the back. We can tell you how to wire it to optimize the amp.
Old Jan 31, 2003 | 09:34 AM
max'n out's Avatar
Ask the guy what they are then.
ivorton23
Sep 28, 2015 09:08 PM
popdedop
Sep 11, 2015 11:17 AM
Violator
Sep 9, 2015 10:14 AM
