speed sensor error - check engine light
Old Feb 13, 2003 | 08:18 AM
rreford's Avatar
Hi! Hoping someone can help here. The check engine light is on, and the error codes point to a fault in the speed sensor ('97 SE). Local dealership says that I can get a speed sensor for $28, but they also say that the speedometer must be replaced as well. Total cost of $350. I don't understand why, and they're not the most reputable dealership around. My questions: Is this a common problem? What is involved in replacing the speed sensor? Is there truly a problem with the speedometer as well? Thanks for any input!:
Old Feb 13, 2003 | 09:54 AM
PCGuRu2K's Avatar
Re: speed sensor error - check engine light
Does your needle work for your speedometer?
Old Feb 13, 2003 | 10:13 AM
rreford's Avatar
Re: Re: speed sensor error - check engine light
I haven't seen any problems whatsoever with the speedometer operation or accuracy.
Old Feb 21, 2003 | 08:20 PM
deadmeat522's Avatar
i am having the same problem now i changed the speed sensor which took all of an hour but my speedometer still is not working if you manage to get yours fixxed let me know what you had to do and i will do the same
Old Feb 22, 2003 | 05:12 PM
rreford's Avatar
Apparently my speed sensor is out, but my speedometer works absolutely fine. Maybe a speed sensor swap will do it for me? What is involved in changing out just the speed sensor?
Old Feb 22, 2003 | 07:38 PM
take off the air cleaner box its on the transmission in the back towards the middle of the car. Its only held on by one bolt and plugged in. Its a dealer only part but is only 23.15 plus tax, roughly 28 bucks.
mrc00l88
Jan 25, 2024 01:14 PM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
