Problem with my screen.
Old Feb 27, 2003 | 09:54 PM
_DRU_'s Avatar
For some reason, my screen just stops working. I have to take out the fuse powering the screen and then put it back in and it works fine. Do you know what might cause the problem or how to fix it? It has happened about 3 times already. Thanks.
Old Mar 2, 2003 | 09:33 AM
Cumalittle
Re: Problem with my screen.
u have wat they call a high open...
Old Mar 2, 2003 | 09:46 AM
_DRU_'s Avatar
Re: Re: Problem with my screen.
Can you help me out a little on what that means?
Old Mar 2, 2003 | 10:32 AM
Cumalittle
Re: Re: Re: Problem with my screen.
high open is a high resistance open...meaning...there is just enuff contact somewhere that will turn it on for so long...after current passes thru it so long..it pops it open...we have problems like this alot w/ phone cables...and i'm assuming u have the same prob...it's just prob a loose connection in other words...
Old Mar 2, 2003 | 03:12 PM
_DRU_'s Avatar
OK thanks, i will check all connections.
Old Mar 2, 2003 | 03:31 PM
Cumalittle
check the power...cuz if u have to take the fuse out and put it back in...it works for a while then stops...so it leads me to believe that u have some loose connection there or bad solder joint...
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
homewrecker
Sep 24, 2015 07:01 PM
