single sub
Old Mar 1, 2003 | 11:06 AM
redmaxpa007's Avatar
i SeE what you did therE
single sub
what single sub would you recommend?
i would like a 12in sub..
tank you..
Old Mar 1, 2003 | 11:59 AM
Cumalittle
Re: single sub
tank you..
if u like 12 in then 12 in it is...i have (1) 15 in round kicker solo baric...um...it hits...
Old Mar 1, 2003 | 01:52 PM
InfamousOrange's Avatar
sq- diamond tdx series
sp- Kicker L7 series
Both- JL w7 series
Old Mar 1, 2003 | 02:35 PM
Nismo's Avatar
Both- JL w7 series
Now what would you recommend for both spl and sq minus the heavy weight?
Old Mar 2, 2003 | 07:35 AM
jmax
Hahahahhahahhaha
Hahahahhahahhahaha
Hahahahhahahhahhaha
You are joking right? High motor strength is how you get SPL. High quality motor build up, motor strength and suspension is how you get SQ. You can't have either with the light weight requirement. Even if you use neodymium for the magnet, it'll be heavy.
That being said the W7 might be the best for both SQ and SPL combined on a cost no object budget. But the enclosure size is quite a bit larger than another sub with very good SQ and slightly higher efficiency. That sub being the Adire Audio Brahma. But honestly decide if you want SQ or SPL. Because many who choose SQ later find out that is not what they wanted. Also decide what your budget is.
matts95max
Apr 23, 2025 10:44 AM
DJLAX152
May 4, 2021 11:46 AM
spazma7ik
Jan 12, 2017 09:38 PM
Max139617
Sep 29, 2015 06:44 PM
