HELP! Bose questions (Studman? )
Old Mar 1, 2003 | 01:16 PM
MiniRX7's Avatar
OKay.. i have searched, and i still don't understand this.
I have a 2003 maxima iwth BOSE audio. In my 2002 i installed the stuff because i have an aftermarket head unit..
But this time round i want to use the factory HU. How does the bose interface differ from a regular line convertor?
I am going to take the output from the headunit (before the bose amp) and use a line converotr there. WHy is the bose convertors so special if you are just taking the signal on the INPUT side of the bose amp??
Please let me know because I need to proceed with my installation
ED
Old Mar 2, 2003 | 02:12 PM
studman's Avatar
Hey hey MiniRX7... glad to hear that you "upgraded" your smashed car for another Max. Lemmie tell you what I know.
First off, I just replaced the stock HU. Read this thread to get info about running the car with the stock speakers/amp. It's sounds good.
As for replacing the speakers and subs, get the PAC AOEM-NIS2 kit. It's a Bose-to-Line-level convertor. The Bose system uses line level, but the voltages vary from 0.7v all the way up to 9.0v, which will kill a pre-amp input on a normal amp. Even my Rockford amp can only tolerate a 4.5v input. The PAC kit will convert the Bose voltages to line level with little-to-no noticable difference. That's what I used to run my subs off the stock HU.
As far as keeping the HU... it's nice looking, but my thread above stated that it was the weakest part of the system. When I replaced it with my Kenwood, I again used PAC's ROEM-NIS2 kit (they just change the cables, so you don't have to buy the OEM-1 unit again) to hook up the HU to the Bose amp. If you are looking for quality, crisp sound, replace the Bose HU. I'd still recommend scrapping the Bose completely, but I'd recommend that the HU be replaced first. HU = weakest link.
Old Mar 29, 2003 | 08:02 AM
vqman
I searched google for "PAC ROEM-NIS2" and it didn't have anything.
where can I buy one of these, and how much do they cost.
also, the PAC link above doesn't work anymore.
thanks
-vq
Old Mar 29, 2003 | 02:33 PM
maximamaybe's Avatar
thanks
-vq
Go to AffSave.com. You can call them and get the ROEM-NIS2. I paid 59.95 shipped. Well, I had to pay tax because I was in Texas. Anoter option is Tune Town, but it was 80 + shipping.
Old Mar 29, 2003 | 08:37 PM
vqman
ROEM-NIS1 89-94 Nissan w/Bose
ROEM-NIS2 95-99 Nissan w/Bose
I have a 2k3, does the ROEM-NIS2 work for the 2k3?
and this thing does what exactly?
I was under the impression that this was a converter that allowed me to run a non BOSE amp of my BOSE HU.
I want to keep the BOSE HU, and hook a different amp and speakers to it...with this it is possible...right?
-vq
Old Mar 30, 2003 | 11:36 AM
studman's Avatar
The AOEM-NIS2 and the ROEM-NIS2 both will work for 1995-2003 Bose radios. I haven't seen a 2004 radio yet, but as long as Nissan didn't change the radio connectors, it would work for 2004 as well.
The AOEM-NIS2 is a Bose-to-line-level convertor.
The ROEM-NIS2 is a line/speaker-level-to-Bose-level convertor.
The main guts of both of the AOEM-NIS2 and ROEM-NIS2 is the OEM-1. The cables are the only thing that are different between the 2 sets.
The AOEM-NIS2 will do that for you. The AOEM-NIS2 is designed for those wanting to keep their stock HU, but replace (or add) speakers, amps, and/or subs.
The ROEM-NIS2 is designed to replace the stock HU, while keeping the Bose amp and speakers.
Yes. Get the AOEM-NIS2 kit.
Old Mar 31, 2003 | 07:04 AM
I30 Boogie's Avatar
OK...thanks Studman ....now what if I want to replace the HU AND interior speakers as well as run a 4 channel and a 2 channel amp? Will the ROEM-NIS2 allow me to do all of this without completely re-wiring the Bose?
And do you know the max wattage per channel rating for the OEM-1? I'm running an Alpine HU rated at 60x4...is this too much for the OEM 1 to handle?
Old Mar 31, 2003 | 07:11 AM
I'm not studman, but if you want a new headunit and new amps, I don't think you need that kit. Those kits are only necessary if you want to keep any part of your Bose system.
I wanted to keep the Bose headunit and amp for the front and rear. Therefore, I purchased the AOEM-NIS2. Studman wanted to replace the headunit, but keep the stoke bose for front and rear. Therefore, he purchased the ROEM-NIS2.
If you want to add a new headunit and completely change the amp for fron, rear and sub then you don't need any of the PAC converters. All you would need is the adapter for the Nissan wiring harness. You could get that from crutchfield.
Old Mar 31, 2003 | 07:28 AM
I30 Boogie's Avatar
THANKS MAN!! That is exactly what I was thinking!!
Old Apr 17, 2003 | 12:55 PM
MarcusJY's Avatar
Can some one tell me where to purchase the AOEM-NIS2. I didn't see it on any of those sites.
Old Apr 17, 2003 | 12:59 PM
See the following link. www.affsave.com/pac5.htm
Old Apr 17, 2003 | 01:14 PM
MarcusJY's Avatar
Thank you very much!!!
Old Apr 17, 2003 | 01:16 PM
GaMax97GLE's Avatar
You may also want to make sure your amp needs this adaptor first. I went to HiFi Buys, told them what amp I had, and the installer said I already have that built into my amp, and my current set-up of tapping into the Bose sub does the same thing as that adaptor would do for a different amp.
Old Apr 18, 2003 | 03:46 PM
MaxinOutSE's Avatar
Studman why can't u put the line converter on the wire that connects to the bose sub
Old Apr 18, 2003 | 09:30 PM
studman's Avatar
Nothing says you can't. But the signal going to the Bose sub has been EQ'd and Crossovered. So why would you want to feed your subs a signal that isn't truely the source, but yet tuned to the Bose system?
Old Apr 19, 2003 | 12:24 AM
Jared611's Avatar
Adding an Amp
WOW guys this info i awesome. I want to do basically the same thing. Just add and amp. Do do this your saying i would have to purchase the AOEM-NIS2(right?) Also, what wires do i have to tap into for the signal and more important where are they in the car. I have a 2000 Max with BOSE. Thanks for any help.
-Jared
Old Apr 19, 2003 | 07:59 AM
studman's Avatar
I'm working on a Bose FAQ that will have pictures and all, but that's not ready yet. Basically, the PAC AOEM-NIS2 kit fits between the factory HU and the factory harness that plugs into the HU. It's plug and play. It does not require tapping any wires, splicing, etc. You just remove the factory harness from the HU and insert it into the AOEM-NIS2 kit. Then you take the connector from the AOEM-NIS2 kit and insert it in the factory HU. The rest is basically self-explanatory.
Old Dec 24, 2003 | 08:54 PM
ABS's Avatar
ABS
Moderators Please Read
If this thread is not already in the audio FAQ, please add it or make it a sticky. Thanks!
Old Mar 24, 2005 | 05:20 PM
Shawoo1969's Avatar
96 head unit ?
HELP! I am wondering if there is a connector/adaptor that will allow me to use aftermarket speakers keeping my 96 Max bose head unit? Thanx for any info provided.
Old Nov 10, 2005 | 02:10 PM
Pres7's Avatar
I was also wondering that, I just want to replace the stock Woofers with some aftermarket ones in my 6th Gen Maxima but for some reason the Right Subwoofer has 4 wires where the Driver side sub only has two like a regular speaker. Anybody know what to do with the other two wires?
Old Nov 10, 2005 | 08:57 PM
Pearl96Max's Avatar
I tend to get a bit irritable
If your adding an amp, then its not a problem. SImply splice female RCA leads behind the HU and run them like you would if you had an aftermarket HU.
D@mn this is an OLD thread...
Old Nov 10, 2005 | 08:59 PM
Pearl96Max's Avatar
The 4 wires is a jumper to the other speaker. I wouldnt recommend just replacing them. Adding an amp to power them would be much more benficial.
Old Nov 10, 2005 | 10:57 PM
Pres7's Avatar
Thanks for the feedback,
You dont think that replacing them with some aftermarket subs would make much difference? I was trying to get away from ripping apart the interior running power wires for a separate amp.
Old Jan 30, 2006 | 11:53 PM
indeep's Avatar
hey i have a 99 maxima just wanted to know where is the factory amp located the bose amp?. i besically wanna keep my bose head unit and just add aftermarket amp and subs.. so your saying i need to purchase a AOEM-NIS2 ??
Old Jan 31, 2006 | 11:14 AM
djfrestyl's Avatar
Suspension Yoda
I can't believe you're still scrounging for answers.
The factory amps are located in your trunk. One is along the back wall (behind the rear seat) and the other is integrated, essentially, into the subwoofer.
You need to splice RCA's into your Bose preouts at your HU, as well as find a remote turn on lead. Run power from your battery. Find a bolt in the trunk for your amps. That's all.
Old Jan 31, 2006 | 11:24 AM
filtor1's Avatar
Thread from the dead.....
Old Jan 31, 2006 | 11:30 AM
djfrestyl's Avatar
Suspension Yoda
Agreed. But this indeep character is bothering me.
Old Jan 31, 2006 | 07:08 PM
indeep's Avatar
lol relax my friend..
Old Jan 31, 2006 | 08:47 PM
filtor1's Avatar
I think I will sit here and let you two work it out.
Old Jan 31, 2006 | 09:27 PM
Pearl96Max's Avatar
Nothing to work out....Both are wrong.
indeep...check the FAQs rather than digging up old threads. All the info you need is there.
Nilesh..its a 4th gen = no sub, and the amp(S) are at Each speaker.
Old Feb 1, 2006 | 01:05 AM
ratha77's Avatar
indeep, read the damn thread, and you will have your answers
Old Feb 1, 2006 | 07:11 AM
djfrestyl's Avatar
Suspension Yoda
Doh. Skimming posts FTL.
Old Apr 15, 2007 | 05:05 PM
jbran555's Avatar
hey, i want to keep my bose HU and the stock Bose speaker, I just want to get some subs, probably 2 12" MTX with a 1200 watt MTX amp, with a ported box, and I have a 2000 Maxima GLE. what do you guys think? how should I go about doing this?
Old Apr 15, 2007 | 05:15 PM
slickrick's Avatar
having kpr10is doing the install...
Old Apr 15, 2007 | 05:23 PM
filtor1's Avatar
+1. And in my garage at that.
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
popdedop
Sep 11, 2015 11:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
