Help 2 12s w6s or 1 12 w7
Old Mar 2, 2003 | 03:52 PM
jeavel
I'm hooking up my trunk but have a problem ok here it is i got an yellow op batt running to my 300 amp anl fuse to my mtx 81000d amp which i think pushes out 1200 watts so if i get the 2 12w6s i get an 1800 poweracoustik amp free from my dawg so can i put each amp on each jl w6 there dvcs if so do i need a cap and what else ?Then on the other hand i can get the w7 12inch and run it on my mtx 81000d amp What yall think Help me out ? What would sound better ? Can i run both of these monster amps ?
And yo anyone needs a good sony deck for cheap email me jeavel@hotmail.com its a ca-760 mobile es
Old Mar 2, 2003 | 04:31 PM
JSClark's Avatar
Damn, I think one 1200W amp would be good enough
I say the one 1200W amp with the 2 12" JL W6's, but I don't think their power rating will be substantial... maybe 1 W7 on one of those 1200W amps then??
Old Mar 3, 2003 | 03:31 AM
kingrukus's Avatar
no more maxima...
That mtx 81000 pushes out more like 1500wrms. Use that single amp to power both W6's. You do not want to use 2 amps of different makes/models to power your set of subs. Besides the power that your 81000 is making can rip apart both of those W6's (if they are the first generation). Are they w6v2's, or the first generation? With respect to choosing either 2 W6's, or 1 W7 it all depends on which can be wired down to 2 ohms, such that your 81000 will give max power. If you can get a 2ohm load wiht the W7, I would go with that in a nice ported enclosure.
expressinme
Feb 23, 2005 08:25 PM
Ryanb126
Feb 15, 2004 09:07 AM
OpTi
Jun 9, 2003 09:41 AM
MAXSRB
Mar 11, 2003 08:27 AM
TheMax95
1/4 and 1/8 Mile Racing
19
Mar 2, 2003 08:21 AM
