Amplifier cuts out...Why?
Old Mar 11, 2003 | 11:44 AM
1FSTMAX's Avatar
This is my current system configuration:
2 12" Kicker L7 Dual voice coil
1 1500bd Rockford Fosgate Amp
2 1 Farad Caps
Everytime it turn it up the volume on the HU, the amp cuts out. The power indicator light on the amp stays on, but no sound comes out of the subs. If I leave the volume at a low setting or medium setting the amp stays on. What could this be caused by? I have checked the Ohm's load on the speakers and it matches with the amp. Could it be problem with power delivery? Or a ground?
Old Mar 11, 2003 | 12:19 PM
H.N.I.C.95's Avatar
Re: Amplifier cuts out...Why?
2 1 Farad Caps
I had this same problem cause by faulty RCA's
Old Mar 12, 2003 | 05:26 AM
Pearl96Max's Avatar
I tend to get a bit irritable
2 1 Farad Caps
What is the impedance level you are getting from the speakers? How are they wired and which are they? What can your amp handle? A little more info and Im sure we can help.
--Don
Old Mar 12, 2003 | 07:16 AM
Kojiro_FtT's Avatar
2 1 Farad Caps
How are those kickers wired, and what's the impedence? You could be overheating the amp if you wired the subs wrong; say for an impedence of 1 ohm. I don't think RF amps are 1 ohm stable.
Old Mar 12, 2003 | 09:13 AM
Supa Lao's Avatar
My buddy had that problem and he needed to get a high output alternator. And just like everybody else, check the impediance the amp is seeing also
Old Mar 12, 2003 | 09:18 AM
1FSTMAX's Avatar
The kicker subs are wired in a 2 ohm configuration, and is putting a 2 ohm load on the amplifier. The amp is designed to push it's maximum power at two ohms. Thanks for the help.
Amp specs: http://www.rockfordfosgate.com/ez2/M...owerAmplifiers
S12L7 Sub Specs:
http://www.kicker.com/ShowPage.cfm?f...enu=SUBWOOFERS
Old Mar 12, 2003 | 09:35 AM
Redmax's Avatar
Redlinemax Owner
So the solo you have is Dual Voice coil 4ohms?
Old Mar 12, 2003 | 09:37 AM
1FSTMAX's Avatar
Dual 2 ohm voice coils.
Old Mar 12, 2003 | 10:44 AM
Kojiro_FtT's Avatar
So you either wired it with the voice coils in parallel and the speakers in series or the voice coils in series and the speakers in parallel; correct?
What else do you have in your system? It is possible that you are drawing too much current and will need an alternator upgrade. According to the documentation that amp typically draws 90 amps.
Old Mar 12, 2003 | 10:57 AM
1FSTMAX's Avatar
Yeah the speakers are wired like this:
We are running another amp for the mids and highs.
We hooked up a Crossfire BMF 1000d to the L7 in a 2ohm configuration, and the amp picked up the subwoffers with no problems. We turned up the system volume up high, and the Crossfire amp sounded great.
Old Mar 13, 2003 | 08:23 AM
Kojiro_FtT's Avatar
Sounds like you are just pulling too many amps. That Crossfire is a much smaller amp than the RF; so if the Crossfire was fine, than the RF is just too big. Either upgrade your alternator or buy a smaller amp, like the Crossfire.
Old Mar 13, 2003 | 08:35 AM
Redmax's Avatar
Redlinemax Owner
I don't think hes pulling too much amps. I've pulled way more than he is on my car with no problem. The amp may be defective. Try this, Wire 1 sub into the amp one voice coil into each channel of the amp. this way the amp sees a 2 ohm load on each side. Then turn the sucker up. If your amp is still cutting out, then your amp is not 2ohm stable. If it was supposed to be, then the amp is faulty. If it does not cut out, then you had your speakers wired wrong.
Old Mar 13, 2003 | 09:01 AM
Kojiro_FtT's Avatar
Whoah, bad idea. You are not supposed to wire the voice coils to different channels, you could ruin the sub. JLAudio's explaination
Old Mar 13, 2003 | 09:18 AM
Redmax's Avatar
Redlinemax Owner
If the amp is running mono you will not have any problem. with the scenario u poste. but even if he just ran the main coil. on one channel it would run the same test. but i think i just answered his and my own question which is the problem is that most amps run 2ohm stable in stereo but not 2ohm mono I wonder if he has the amp running 2 ohm mono
Old Mar 13, 2003 | 09:20 AM
Unibomber's Avatar
heh i had the same problem and it ended up being the fuse was too small :/
Old Mar 13, 2003 | 09:26 AM
1FSTMAX's Avatar
I just got off the phone with RF tech support, and they have determined that I have a bad amp.
Old Mar 13, 2003 | 09:55 AM
Pearl96Max's Avatar
Hey Corey, what you and Kojiro are both missing is that this amp is a mono amp, so: you cannot hook up to "seperate" channels
-_Don
Old Mar 13, 2003 | 10:12 AM
Kojiro_FtT's Avatar
-_Don
But if it was a multi-channel amp but with a mono signal, I still wouldn't do it; a mono signal going through different amps can still have slightly varying outputs.
Old Mar 13, 2003 | 11:26 AM
Redmax's Avatar
Redlinemax Owner
Duh
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
EdRomo86
Sep 12, 2015 07:49 PM
