Wiring help
Old Mar 14, 2003 | 11:20 AM
waveridr85's Avatar
Wiring help
Ok, not big on knowledge with stereos..... how would i set up THE WIRES TO THE SUBS for a punch 700 w amp that can be brigded to put out 350rms x 2 (at 4 ohms) to 2 4 ohm rockies subs
Old Mar 14, 2003 | 12:42 PM
Sirius1's Avatar
Re: Wiring help
There should be markings on the amp for mono speaker connections. When you bridge the front 2 channels, you only use one + and one - terminal. Same for the rear. Just use the bridged markings to the + and - of each speaker from the front for one sub and the rear for the other and it should work.
Old Mar 14, 2003 | 01:22 PM
waveridr85's Avatar
Re: Re: Wiring help
so basically get a wire from the amp to one sub, a wire from that sub to the other, and a wire from that sub to the amp?
Old Mar 14, 2003 | 01:39 PM
Sirius1's Avatar
Re: Re: Re: Wiring help
I just looked at the 700 on line. It is a 2 channel amp. You will run the subs in series since they are 4 ohm subs. The way this is done is pretty simple. But you have to make sure the connections are correct or you will end up with no bass.
You take the bridged + terminal from the amp and run it to the first subs + terminal. You then jump a wire from the negative terminal of the first speaker to the positive terminal of the second speaker. Then you run a wire from the negative terminal of the second speaker back to the negative bridged terminal. This puts the speakers in Series, in essence causing the amp to see a load of 8 ohms, which is cut in half because you are bridging the amp.
You will get more output from the amp if you run two 8 ohm subs parallel. That would allow the amp to see a load of 4 ohms, which is like 2 ohms stereo. The amp will work harder because of the lowered resistance. But I am sure you will end up with ample bass if you hook up what you have properly.
Hope this helps.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
