Installing complete system today.
Old Mar 24, 2003 | 05:20 AM
crazyravr's Avatar
Few questions.
1 - Best point to drill thru firewall and do I need to be careful not to drill thru anything important on the other side.
2 - Grounding amps. Ground them at the same point or just same length round wire is enough.
3 - Re-Use existing wires for front speakers or run new ?
any help will be appreciated.
thanx
Old Mar 24, 2003 | 06:36 AM
nupe500's Avatar
Jedi Knight
Re: Installing complete system today.
Originally posted by crazyravr
Few questions.
don't drill...find an existing hole/grommet and use that as an entry point.
ground them at the same point
depends on what kind of power running to the speakers or sound you want. It is obviously more work to run new wires if you want/need them hope that helps
thanx
Old Mar 24, 2003 | 10:12 AM
crazyravr's Avatar
I have looked for a while and cant find a hole thru fire wall... I will look again 2day... there are some grommets (do I pull them out or screw them out?)... also this is for #4 wire...
Yea as for the speakers I will be runing a new wire..
Old Mar 24, 2003 | 11:04 AM
releasedtruth's Avatar
rilla dope
There is supposed to be a spot in the firewall near the wheel well to pull some wire through, but I like breaking things so I made my own and grommeted them. Drilled 2 holes by the brake pedal, there's a little panel on the inside, works perfect for the dual 4Gs. I also have my amps grounded at separate places, but to each his own.
Old Mar 24, 2003 | 01:00 PM
crazyravr's Avatar
Yea well the thing is if i drill i dont want to drill thru something important hehehe... so i will look a bit more a a hole.. and if there is none.. then i will make my own
JRod28
Dec 29, 2023 09:56 PM
95Maxi
35
Sep 2, 2015 10:37 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
