Blinkers and power locks ?
Old Mar 26, 2003 | 04:32 AM
crazyravr's Avatar
Today going to work I noticed my change lane indicators (blinkers) stopped working... they dont blink on the dash or on the outside. All the light are on fine when turn them on for night driving. I also noticed that my passanger power lock doesnt lock or open with all the other doors... it did fine when I got in the car. Can anyone help ? IS this a fuse ? IF so where are those fuses ?
thanx
Old Mar 26, 2003 | 03:13 PM
studman's Avatar
The fuse for the blinkers is in the fuse box in the main cabin. If the fuse is blown, your hazard lights won't work either.
As for the passenger's door lock, check the connector from the door to the car. It's near where the hinges are. If it's ok, then see if the window works. If it does, then it's probably the door lock motor that's gone bad. If the window doesn't work, then you've got a bigger problem (like a bad harness) and probably should visit the dealer/repair shop.
Lastly, check the fuses underneath the hood. They are near the battery. If all checks out ok, I may see a dealer visit in your future.
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
