CD changer for 2003 SE
Old Apr 15, 2003 | 06:28 AM
tecman4's Avatar
Hi,
I have a 2003 se without bose.
I want to put a Maxima 6-Disc Autochanger in and I was wondering if anyone else tried to install this.
Is it hard? do I need to run wires to the radio or are the wires already installed?
here is the link http://www.nissan-accessories.com/PP.asp?PID=318
Wayne
Old Apr 15, 2003 | 07:06 AM
studman's Avatar
You will need to run a cable from the CD changer back to the factory HU. I'd check to see if that changer comes with the cable before you buy it.
Also, USA Spec makes a changer for the 2002-2003's that are cheaper than the OEM stuff. The model number is SCD-N66E. Crutchfield has it for $299.99 and it says this... "This high-quality 6-disc CD changer plugs into the factory system using the cable adapter — no wire splicing or confusing modifications". I'd look for the unit elsewhere on the net to see if you can get a better price on it.
But if you want the OEM stuff, then make sure that changer comes with the cable before you buy it.
Old Apr 15, 2003 | 07:31 AM
tecman4's Avatar
Where is the factory HU?
Old Apr 15, 2003 | 07:54 AM
studman's Avatar
In the dash? Isn't that where most HUs are located. The cable plugs into a connector on the back of the radio.
Old Apr 15, 2003 | 08:00 AM
tecman4's Avatar
So I would need to remove the radio?
Sounds difficult.
Mahmuth
Aug 16, 2024 08:23 PM
Max139617
Oct 19, 2016 11:34 AM
Maximan190
Dec 16, 2015 06:01 AM
NewMax03
Oct 7, 2015 08:27 AM
