Another Head Unit Question
Old May 1, 2003 | 06:57 PM
remykins's Avatar
Ok, I ripped apart my max tonight to try and see how my install would go and I realized it is going to more of a pain than I thought. I have an Alpine CDA-9815 and it requires a direct run to the battery. Also when I try to line the screw holes up my trim ring either hits the edges of the dash or sticks out 1/4" from it.
Does anyone have any good suggestions on where I can run the power wire through the firewall at? It looks like all the wires now go through the fender. Im pretty sure I am going to have to drill new holes in the stereo bracket. Nissan loves to make things hard!!!
Any thoughts?
Old May 1, 2003 | 10:50 PM
erty67's Avatar
Decal Specialist
If you open your hood and look at the firewall. You may find a rubber grommet plugging up a hole. That's how i found a hole for my 98
Old May 2, 2003 | 04:32 AM
remykins's Avatar
Yeah, unfortunately on the 2k2 its on the passenger side. Im going to try pulling out the fender well tonight and see if I come up with anything.
Old May 2, 2003 | 09:14 AM
erty67's Avatar
Decal Specialist
I have another thought....Do you really need to run a wire to the battery? Most HUs just need a "constant" +12V source. You should be able to find a wire off of the factory radio harness that has +12 with the car off. Just use a volt meter or test light.
Old May 2, 2003 | 10:32 AM
remykins's Avatar
That would normally be no problem. Unfortunately, the HU that I have has a hybrid amp in it that causes a high draw and requires a 10 gauge wire run to the battery. Gotta love Alpine.
Old May 2, 2003 | 05:48 PM
erty67's Avatar
Decal Specialist
got ya!
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
