OPINIONS WANTED: Upgrading my 2002 Bose speakers to...
Old May 2, 2003 | 10:07 AM
VMosser323's Avatar
an Infinity set-up. I have already purchased an Infinity Basslink to replace my Bose sub and Polk EX3500 tweeters to replace the stock pillar tweeters, but I have not installed these items yet. I want to do the door speakers, but my question is this: which Infinity Kappa speakers should I get?? The Kappa 63.5 3-way component 6-1/2" or the Kappa Perfect 6-1/2"?? I know the Basslink has its own amp, but will I need an amp to maximize the door speakers?? If so, suggestions are welcome.
I am not big on knowledge of car audio, so keep that in mind, but I would like to keep it all Infinity.
Old May 2, 2003 | 12:51 PM
maximamaybe's Avatar
None of the speakers will sound very good with the stock BOSE amp. The mids are like 1 ohm and the Infinitys will be 4. That means much less power going to them. If you are going to replace mids, put in a aftermarket amp.
Old May 5, 2003 | 07:57 AM
VMosser323's Avatar
WHat size amp would you suggest to run all of the above mentioned. The Basslink already has it's own amp. What size amp would I need to run the Polk tweeters and all 4 Kappa 6-1/2"s in the doors??? Could I use the Bose amp that is currently running the stock sub???
Old May 5, 2003 | 08:02 AM
I would recommend a JBL BP 80.4 from Ikesound. It is $149 shipped. If you want a better amp than that, look into Pheonix Gold or Alpine. They make great highs amps.
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
popdedop
Sep 11, 2015 11:17 AM
A32goldylocks
Sep 2, 2015 06:39 AM
