Anyone having trouble with their JL 500/1
My lights keep dimming with the 500/1. I've tried everything even got a cap. I just put in a new alternator and optima red top battery. And I also have a 400x4 alpine amp.
Here how I got it wired. 2 gauge main power wire to a distrabution block and from the distrabution block a 4 gauge going to cap, 4 gauge going to the JL 500/1 and a 8 gauge going to the alpine.
It's getting on my nerves. Can't figure out what's going on.
You might have it wired wrong. I have 4-gauge Power wire going from the battery to the capacitor. From there, I have the distribution block, which goes to each of my amplifers. It sounds to me like your capacitor isn't wired to your amplifier, unless I just misunderstood you. I don't know much about wiring though, so I could be wrong.
-Nick
-Nick
-Nick
-Nick
Originally posted by jmax
Run the two gauge straight to the cap. Then to the dist - fuse - block. What 4 channel Alpine amp do you have? And what year is your car?
You should be useing a 2 gauge or better ground to the cap anyway.
Alpine has probably made 100 different 4 channnel amps in the past 15-20 years. Which one are yuou using? It is tough to determine how much current it needs if we don't know which amp it is and the power output.
It is only one of many potential problem area's. Ground point could also be bad. Or not properly prepped. Ground from battery to chassis or chassis to block also an issue. You do not have very much power in your system. For that reason It is likely something basic.
Originally posted by eaglclon
thanks jmax. Imma go ahead and reground everything.
