need advice asap
Old May 17, 2003 | 03:20 PM
dr3ams661's Avatar
need advice asap
I have a rockford fosgate 4 channel amp that I would like to hook up to the 2 sets of infinity kappa components that I just bought. Is it possible to hook it up to the factory 2001 Maxima non-bose deck, without getting any feedback or alternator whine? If so, how would this be possible or any recommendations. I would like to keep the stock deck as much as possible and do not want an aftermarket deck. Thanks in advance.
Old May 17, 2003 | 04:48 PM
y2kse's Avatar
I accomplished what you're after using an Alpine amp with built-in high-level (speaker) inputs. I experience no noise whatsoever.
Does your RF amp have high-level inputs? If not, you'll need to install a high-level to low-level converter such as:
http://www.thevideodoctor.com/pages/HSHL-2.htm
Then you'll have to test it to find out if your RF amp will operate noise free.
Old May 17, 2003 | 07:23 PM
dr3ams661's Avatar
Thanks, I got the PAC brand hi-low converter. Does anyone know how good that is?
Old May 18, 2003 | 01:06 AM
andrew3616's Avatar
I just did the same install as you are talking about. I would buy a line out converter with signal gain adjustments off ebay. Then you have to cut the wires from the harness and stick them into the converter. Just PM me ill tell you everything.
Old May 22, 2003 | 07:19 PM
dr3ams661's Avatar
Does anyone have pictures of this done to their car?
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
