Gas Tank
Old May 27, 2003 | 04:33 PM
Frosty's Avatar
Gas Tank
I want to bolt my sub box to the floor of the trunk, where is the Gas tank located, I don't want to puncture it with screws.
Old May 27, 2003 | 04:39 PM
Playero's Avatar
Sanduguero
Re: Gas Tank
i want to know this too!!! good question i think is the left side inside the trunk?
Old May 28, 2003 | 09:52 AM
largestal's Avatar
I dropped the muffler and heat shield, drilled through near the bolts that the muffler heat shield hang from with no problems whatsoever. That way the bolts are hidden and protected.
Old May 29, 2003 | 08:59 AM
Blaximazx's Avatar
What about rust and corrosion on the bolt? Did you seal the outside
Blaximazx's Avatar
Old May 29, 2003 | 11:10 AM
largestal's Avatar
Galvanized bolts and a dab of caulk on the bolt as I put it through the hole. Been doing it the same way for many years and on many vehicles. Stainless is an option as well.
After the caulk skins over I have been known to spray a bit of undercoat on the entire area just to make it look nice and 'factory'.
Let me know if I can help.
Old May 29, 2003 | 12:07 PM
max'n out's Avatar
THe gas tank is underneath the back seat
Old May 29, 2003 | 01:59 PM
Frosty's Avatar
HAHA for some reason I don't feel very Safe anymore in the max.
Old May 29, 2003 | 04:50 PM
max'n out's Avatar
Why
Old May 29, 2003 | 04:56 PM
Frosty's Avatar
Just kidding, but I was refering to the fact that the rear passengers are sitting on top of almost 19 gallons of gasoline....BOOM.
Old May 29, 2003 | 04:58 PM
max'n out's Avatar
Far better and much more safe than the pinto was
Old Jun 13, 2003 | 08:40 AM
Show Maxima's Avatar
Actually its 16 and some change of gas. if you got that big of a tank let me know wuz up....
Old Jun 13, 2003 | 08:57 AM
max'n out's Avatar
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
