HU bracket screw is stripped...help
Old May 29, 2003 | 10:07 PM
rwatt1981's Avatar
I'm removing the stock HU out of my '98 GXE and I have it completely out, however I can't get them damn screws on the bracket removed. I managed to pull 1 out but the other 3 are just about stripped. What should I do now?
Old May 30, 2003 | 06:34 AM
largestal's Avatar
I had the same problem with the phillips heads stripping out. Them little SOB's are tooooo tight.
I had to take my dremel with a cutting wheel and cut a deep groove into the screw and use a regular screwdriver to get them out.
Hardware store has replacements.
Old May 30, 2003 | 06:46 AM
Kojiro_FtT's Avatar
Yeah, I had the same problem. Like 4 of them stripped. I drilled em and used a screw extractor. The screws were tempered too, so drilling took a while. I was PO'd.
Old May 30, 2003 | 05:20 PM
SuperChris's Avatar
Infiniti 35 Double G's
Same problem back in January...I took the caveman approach and beat the tihs out of the HU until it was in 1,000 pieces. Took an hour, but that did the trick...
Old May 30, 2003 | 06:33 PM
MaxSE03's Avatar
Go by an Easy Out from Sears or where ever. They will come out! Easy Out, vise grips, and hammer works every time.
Old May 30, 2003 | 09:12 PM
chinaonnitrous1's Avatar
Okay guys...its 1000 times easier if you put force to tighten it a tiny bit..then back it off. Its soo much easier. ive done it that way about 100 times now. Only stripped one.
Old May 30, 2003 | 09:25 PM
Maxtank's Avatar
I got some friends who are going to school for motor cycles take an impact driver to it, busted em loose :-)
Old May 30, 2003 | 11:37 PM
ny96max's Avatar
take a hammer and a philips head screwdriver and firmly hit the screw-head, that will break the lock between the screw and radio body. Then easily unscrew it.
and if that dont work just drill them out!
this should not be a brain teaser here
Ant
Old Jun 2, 2003 | 12:34 AM
rwatt1981's Avatar
Ant
took your advice man and BAM the suckers came out in like 10 seconds...felt good getting some anger out though hehe!
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
Calabar
Oct 5, 2015 09:57 PM
sliptap
Sep 30, 2015 05:57 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
