is 3 in 1 silent step underlayment a good sound dampening?
Old Jun 1, 2003 | 08:36 PM
shane12286's Avatar
i just went to home depot and i couldnt find any peal and seal so i thought i would try out this stuff called 3 in 1 silent step underlayment for under hard wood flooring. it says that it is a great sound dampener. i was wondering if anyone has tried this or has heard anything about it. it was about 67 cents/ sq.ft. if not what are some reasonable alternatives to this that i can purchase locally? for not as much as dynamat. thanks alot.
Old Jun 2, 2003 | 12:21 AM
jmax
That stuff is probably too light to do much. But will still do more than nothing at all. What area are you planning ot work on?
Old Jun 2, 2003 | 09:35 AM
shane12286's Avatar
the rear deck and door panels
Old Jun 2, 2003 | 10:53 AM
jmax
For something basically the same as peel & seal, ramm mat, Edead, dynamat extreme go directly to either ramm audio's web site or Elemental Designs and buy direct. For something like the cascade audio vinyl material go to sound down and buy direct. If you get the sound down material make sure you get no thicker than 1/16 inch and get it with the adhesive backing. I think it's about $1.50 / sq ft with the adhesive backing.
http://www.raamaudio.com/
http://www.soundown.com/
http://www.edesignaudio.com/
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
pkfinn
Jan 3, 2016 02:55 PM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
AT978
Aug 15, 2015 06:39 PM
