Have some trouble installing components
I took the driver side door apart and realized I had no clue as to which wire(s) will run into the input of the crossover. Do have to cut a certain wire? If so which one?
Originally posted by handsofstone
you left out some specifics, but i will try to help as best as i can. i have the infinity components. you run the stock wires to the input on the crossover as if it was a speaker.
I'm sorry for not being specific. This is my first time doing components.
I have Bose and I used wires that go from the radio harness to the amplifier harness in the door. I believe the driver's side wires were yellow and brown. they were the same colors on the factory radio harness. I have to pull my door panel off anyway, so I'll double check and get back to you. If you need help, let me know and we can meet up. I live in RI.
Originally posted by MaxPerformanceSE
I don't have the Bose system. At this point I do need help. I will go to the NENOC meet afterall.
well....there may be changes there. The NENOC group wants to reschedule that meet because it's the same day as Import Wars. I don't think there is going to be until July. I'll still meet up with you, if you would like. Sundays are usually good.
I think we should meet up. Sundays are good for me too.
bryants95max
Oct 2, 2015 12:52 PM
markevans999
Sep 10, 2015 04:29 PM
Violator
Sep 9, 2015 10:14 AM
carid
Sep 9, 2015 05:06 AM
