subs acting weird, need help!!!!
Old Jun 16, 2003 | 11:43 AM
mb1's Avatar
mb1
This happened after I hit a big pothole on the highway. My bass shut off for half an hour, then came back on, but it fades from full power to half power. It sounds like 1 of the subs is having a bad connection, and keeps kicking in and out. The weird thing is, that when I check it, everything works fine, but when I drive, thats when the weird stuff begins. Obviously I can't check the subs when I'm driving. I checked just about everything. Could it be, that the pot hole, damaged the capacitor, and it's causing it to not charge and discharge properly?
Old Jun 16, 2003 | 07:16 PM
erty67's Avatar
Decal Specialist
maybe a connection inside the amp With your system on, try tapping on your amp and see if it happens.
Old Jun 17, 2003 | 11:09 PM
jmax
Most likely a loose wire. Could be a power or ground wire. Or a speaker wire.
Old Jun 18, 2003 | 08:17 PM
mb1's Avatar
mb1
It fixed itself
Old Jun 18, 2003 | 09:20 PM
AscendantMax's Avatar
Originally posted by mb1
It fixed itself
check the main fuse on the power cable. my was acting up similiar to that. i popped in a fresh fuse and problemw as solved.
Old Jun 18, 2003 | 10:04 PM
erty67's Avatar
Decal Specialist
I've seen the same thing, but it was a cheap fuse holder.
HerpDerp1919
Sep 29, 2015 02:02 PM
Redfox
Sep 28, 2015 10:41 AM
zmcneely13
Sep 26, 2015 02:26 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
