Help: Bose Wont Work
Old Jun 23, 2003 | 12:21 AM
bombtrack_ratm's Avatar
A little while ago i noticed that 'ERR' will sometimes show up on my Stock Stereo(BOSE) when i put in a CD. That wasnt really my problem. What is, is Now for some reason, you cant hear the music no matter what volume. Cant hear anything, from Radio, to Cd. Now i was told not to bother to fix it because it would cost too much money, so i went to go buy a Rockford Fosgate today, installed it, and the same problem persists. No matter how loud, you cant hear the music. What's the problem? Do 95's have an AMP built in that may have blown a fuse? Help me because i am resorting to singing Whitney Houston's BODYGUARD for my muscial enjoyment.
Old Jun 23, 2003 | 01:16 AM
Is there anyone that can help?
Old Jun 23, 2003 | 01:32 AM
sirveaux's Avatar
Had something similar happen in my car, with an aftermarket system, sound would just cut out all around. Turned out to be shorted speaker wire on one of the speakers. I'd recommend pulling the unit, turning it on, then disconnecting the speakers one at a time to see if anything happens. If so, then you'll have narrowed down which one is shorting and should be able to fix it. Good luck.
-Ryan
1996 Subaru Legacy 2.5GT
Old Jun 23, 2003 | 01:36 AM
So if one speaker goes, it means all go?
Old Jun 23, 2003 | 03:08 AM
sirveaux's Avatar
Not the speaker "going", just the wiring to one of the speakers could be shorting out. I can't say whether or not the whole thing would stop working if one of them were shorted, but this was the case with mine, so it's worth trying this out to see if that could be the problem. I did the same thing, went and bought a new head unit, wired it all up, nothing...then I pulled it out, disconnected one of the speakers (while it was still on) and it worked, so then I traced the wiring for that speaker to the rear of the car where it was pinched under the seat and shorting out. This was my problem, it's possible you have a similar one.
-Ryan
Old Jun 23, 2003 | 07:24 AM
MaximaSE96's Avatar
Maxima Owner
did u check the BOSE AUDIO fuse in ur fuse panel
Kevlo911's Avatar
Kevlo for President
if one goes others still work, my drivers side blew but warrenty fixed it, cd player err i had that too, use cd lens cleaner in it, if ur head unit still has probs, go here http://carstereohelp.com/nissanBoseMax.htm
Old Jun 23, 2003 | 07:28 AM
MaximaSE96's Avatar
Maxima Owner
no there is a fuse that runs all the BOSE amps if that one goes the radio will go on but no sound, i have blown mine a few times
Old Jun 23, 2003 | 07:53 AM
Well there was one fuse that was burned, and i wasnt sure what that was, but it wasnt stereo. There is a fuse in the middle row that isnt burned, but it doesnt have power going to it. How would i fix this problem. I honestly think it's the BOSE fuse that is in the car. But how am i supposed to fix a fuse that isnt burned?
6spd4dsc
May 9, 2022 12:30 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
