Am I Getting Proper Voltage?
Old Jun 26, 2003 | 12:01 AM
MJ23FE's Avatar
Today i had Pioneer DEH-P9300, Diamond Audio HEX S600s, Diamond Audio M361i, Rockford Fosgate Punch 500a2 installed in my car. I used 0ga going from the battery to the fused digital distro block and 8ga going to the amp which has a 60amp fuse in the distroblock. Everything i used is ALL KnuKonceptz. Now, when my engine was off and the contact was on the digital volt meter on the distro block read 12.6. When the engine was running it read 13.9.
Sorry for the blurry pics.
Random pic of the current setup and install.
Now am i getting proper power? Is that normal voltage considering i am only running an amp for my comps which puts 125x2@4ohm. I just got the battery new, its a Die Hard Gold and it puts out 640amps. My one friend said that the 12.6 and the 13.9 is pretty low and that it might be my alternator. I seek another opinion. Any help would be greatly appreciated. Thanks!
-Jalal
Old Jun 26, 2003 | 12:25 AM
MetaOrbit's Avatar
Got Projectors?
Re: Am I Getting Proper Voltage?
It's always been my understanding that the car's electrical system carries about 12v when off and about 14v when running.
I don't think anything's wrong..
Old Jun 26, 2003 | 06:16 AM
erty67's Avatar
Decal Specialist
Re: Re: Am I Getting Proper Voltage?
Old Jun 26, 2003 | 06:34 AM
jmax
Typical car battery is about 12.5. The voltage regulator in the alternator usually runs 1-2 volts higher than the battery voltage in order to charge the battery and power the rest of the electrical devices in the vehicle. I wouldn't worry or complain about 13.9 volts with the engine running.
Old Jun 26, 2003 | 06:44 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Both are very normal and pretty accurate.
--Don
AaronL
Nov 15, 2020 11:52 AM
Noela
Sep 26, 2015 08:22 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
18
Sep 22, 2015 11:39 AM
