Vibrations
Old Jun 27, 2003 | 11:18 PM
98 DBL Black's Avatar
Vibrations
I have 2 Pioneer Premier 12 DVC's with about 500w to each. My rear bumper cover vibrates and so does the spoiler...BAD. I have already "foamed" the trunk lid. Any suggestions??
Old Jun 27, 2003 | 11:20 PM
reygarcia's Avatar
Loved by MrGone longtime
you should use some Dynamat or go to Lowes and get you some Peel-N-Seal for your trunk.
Old Jun 29, 2003 | 10:42 AM
Max2000SE's Avatar
What exactely is this "Peel N Seal" stuff? Anyone use this? How well does it work on cutting down the vibrations....Cost??
Old Jun 29, 2003 | 08:54 PM
NEW2DAGAME's Avatar
I just recently delt with this. I used Peel and Seal on my entire trunk. BTW, its found in the roofing section at Lowes. The price was $12.47 for 25 ft by 6in width. It reduced my rattle alot, but my bumper was still dancing. What I did was take an old t-shirt and cut it in half, rolled it up, and stuffed it inside the bumper between the foam and the metal. I used one piece on each side and it solved the problem. I dont have a solution for the spoiler yet. Hope it was some help.
Old Jun 29, 2003 | 11:40 PM
Cool thank you, anyone with a spoiler solution???????????
Old Jun 30, 2003 | 12:39 AM
HitManSE's Avatar
I probably will soon considering im thinking of a setup thats capable of pushing will over 140db
If you have any "advanced" questions on audio ect... just click Here and register. You'll find alot of useful info there. Btw-are you runnin 500w rms or peak to the subs?
Old Jun 30, 2003 | 09:47 AM
Playero's Avatar
Sanduguero
take out the spoiler and drill a hole in the bottom lip fill it with foam, my guess.... i dont know if is posible!
Old Jun 30, 2003 | 10:51 AM
Max2000SE's Avatar
Wouldnt filling the spoiler w/ foam cause it to bust open??? We may have to just put up witht the spoiler rattle...
Old Jun 30, 2003 | 12:12 PM
500 RMS, Kenwood eXcelon KAC30-XIT, mono @ 2Ohms
Old Jun 30, 2003 | 02:02 PM
silver99
Re: Vibrations
HI, me and my friend just did his car. His rear deck inside the car was vibrating alot.
For your problem i would strip the entire trunk, take out all the carpet and carpeted looking walls until you see the metal, do the same thing to the trunk lid. The use dynamat xtreme and cover the entire area. You WILL notice a difference.
PS you can use something called tsunami untimate or somethiing like that, they sell it at Circuit city and it cost like 1/2 the price of dynamat xtreme. ::ONT GET THE ****TY DYNAMAT, GET THE STUFF WITH THE FOIL ON ONE SIDE AND TAR LIKE SUBSTANCE ON THE OTHER.
One other thing::wear gloves when u put in the dynamat, it cuts you badly and it doesnt seem like it would.
user 11122324
42
Jul 18, 2022 03:35 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
06maxima55
Sep 28, 2015 04:29 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
