cd-r's not working correctly in bose headunit
Old Jul 10, 2003 | 07:45 PM
Maxima 504's Avatar
just recently, my burnt cd's have not beeen reading correctly in my max with the bose. i have heard from people that the headunit cannot be changed to an aftermarket without replacing all the speakers. but i have heard from others that it is possible to change it because there is an adapter that i can use. can anyone tell me which is true? i tried search but couldnt find anything to help me... any info on this would really be appreciated.
Old Jul 10, 2003 | 08:53 PM
moogiemomo's Avatar
Re: cd-r's not working correctly in bose headunit
Did your burnt CD's work previously ? I know that I can't use cd's burnt with windows XP in my car stereo or my xbox.
YOu can use a different receiver with the stock speakers but you need to get an adapter to make it work. Any audio fitting electronics place will be able to do it for you.
Old Jul 10, 2003 | 09:10 PM
SoMarvelus's Avatar
its old school but try converting the mp3's to wav then burn, just go on www.download.com and search wav converter
Old Jul 10, 2003 | 09:15 PM
sirveaux's Avatar
If they worked before but now they don't and you haven't changed the software you use to make them, try cleaning the head unit with a CD cleaner. Obviously the discs you burn at home aren't as high quality as the audio CD's you can buy, and I know from experience that some players can get *****y about them. Much cheaper to clean it first than to change head unit. Also, I'm assuming you haven't changed brands of CD-R's? Some brands don't work in some players. I have Imations I use for data and Sony CD-R's for music, I've never had a player reject a Sony disc.
-Ryan
Old Jul 10, 2003 | 09:28 PM
Ceasars Chariot's Avatar
Old Maxima Legend
nothing to it they make an adapter it was around 40 dollars when i bought one. go to any aftermarket stereo place and they can look it up andorder it for you or they may have it in stock.
try cd-rw and what are you using, i wouldnt doubt it if you are having trouble with any kind of windows media player. get nero !!!
Old Jul 10, 2003 | 09:44 PM
bombtrack_ratm's Avatar
I had to replace just rear's because they had their own amps.
Old Jul 11, 2003 | 09:27 AM
gabex's Avatar
Honestly, when it comes down to it the Bose Headunit blows. One little problem will grow into a big problem when it totally craps out on you. Most people go with an aftermarket HU.
If you're interested, I have a Sony Xplod M-620 for sale. Let me know.
Old Jul 11, 2003 | 10:00 PM
Maxima 504's Avatar
does anyone know if i will keep the same sound quality from the bose speakers if i get an aftermarket HU? i heard that the bose system only works together... can anyone help?
Old Jul 12, 2003 | 11:59 AM
gabex's Avatar
You can keep the same sound quality if you buy an adapter. I bought a Scosche adapter from www.crutchfield.com and now I think my Bose actually sounds better because I have a real EQ to use.
6spd4dsc
May 9, 2022 12:30 PM
dr3am
25
Oct 22, 2015 08:53 PM
Max139617
Aug 29, 2015 02:55 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kirkhilles
Aug 8, 2015 10:53 AM
