Battery Terminal Woes
Old Aug 19, 2003 | 07:56 AM
maxcosity's Avatar
Ok, WTF!!
I've got a 2003 Maxima SE and I just looked under the hood at the battery. To my surprise it has this really gorky looking + battery terminal. It appears to have a normal auto battery terminal clamp on it, but it seems something else is piggy backed to it with a fuse and two wires - looks like some OEM distribution block with one fused output and one normal output. I'm guessing one goes to the alternator, but no clue where the other goes.. *shrug*
Any idea how to install some heavy gauge wiring for an amp using custom terminals and still maintain this OEM battery hookup??
FYI, this is what I'm hoping to install, since it's awesome, platinum, and has a built-in fuse, what more could you ask for... It sits right on top of the terminal post.
http://www.sounddomain.com/sku/ROCCPBCMAX1
Thanks,
Kevin
Old Aug 19, 2003 | 07:32 PM
maximaseefu's Avatar
it looks cool and all but why do you need 2 power cables coming from the battery?
Old Aug 20, 2003 | 10:41 AM
maxcosity's Avatar
amps, alternator, accesory power, etc..
Old Aug 20, 2003 | 12:27 PM
Kojiro_FtT's Avatar
OK, one output is fused the other is not. What's the point? And $30? Give me a break. Use a friggin' ring terminal like everyone else and don't worry about it.
Old Aug 20, 2003 | 12:31 PM
maxcosity's Avatar
2awg or 4awg with a really thin wire terminal is not a very bottle-neck-free solution, though..
Old Aug 20, 2003 | 11:49 PM
i only have one power coming directly off my battery to a distribution block....works great for me. also, what are you going to do with the unfused output?
Old Aug 21, 2003 | 07:23 AM
Kojiro_FtT's Avatar
So don't use a really thin ring terminal, get a thick one. And that batt terminal only accepts up to 4 gauge, not 2. So what are you going to do with the unfused?
Old Aug 21, 2003 | 02:22 PM
PoLo's Avatar
2-Wheelin it...
optima yellow top
interstate round side terminals (not, i repeat, NOT gm side terminals, they are hexagon shaped)
keeps stock terminal, and add audio terminal.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
