Routing speaker wire from cabin to door on 5th gen
Is it possible to do run one through the existing wiring in the door through the molex connector, or do i have to create a new hole for this in my door and cabin?
thanks
thanks
Re: Routing speaker wire from cabin to door on 5th gen
thanks
thanks
Also, here is a pic of what I did. The red arrows point out the multi-pin connector. I took this apart and really didn't see any chance of drilling through it, maybe you could fair better. The yellow arrow is the speaker wire I put in after drilling holes in both the door and behind the kick panels. There are more pics on my homepage if you're interested.
Tony
Originally posted by Pearl96Max
You need to drill from the inside of the cabin. When going into the door your can actually cut a small slit and feed it through there.
--Don
--Don
Tony
Originally posted by Tony Fernandes
Don, I'm not sure we're thinking of the same thing...? When I took apart the multi-pin connector at the door, it was nothing but a big white piece of plastic with male/female pins facing eachother. I didn't see anywhere to feed a wire.
Tony
Tony
Tony
Tony
I mean on the door side of the wiring, not on the body side. Yea on the body side there is no way to get through, but on the door a small slit can be made if you pop out the grommet, slice, then put it back in.
--Don
melteye
May 16, 2016 12:02 AM
doobadoo
Aug 15, 2015 06:43 PM
