sub????
Old Aug 27, 2003 | 01:01 PM
krmaxima's Avatar
sub????
i need a 15 inch that doesnt need that much volume space??? please help. most 15 need about 2.0 volume space but need some thing that needs about 1.5 or smaller. please let me know
thanks
Old Aug 27, 2003 | 01:19 PM
Lytheum's Avatar
dunno how much you want to spend but check out adire audio( www.adireaudio.com) The 15" Brahma doesnt require very much space at all. They also have a few other 15" subs.
Old Aug 27, 2003 | 04:36 PM
jmax
I have a friend with a 15 inch brahma in a box that can't be any more than 2 cubic feet. He used to have it in over 3 feet but the smaller box is actually better, less of the really low bass. In the big box the sub bass was over-emphasized. It probably also helped that be now has a better set of mids and tweets. For an even smaller box you can use the Adire Tumult, built for home and outrageous in car.
Old Aug 27, 2003 | 05:30 PM
filtor1's Avatar
Re: sub????
thanks
Go to ebay and search for Credence under subwoofers. These are the old style Kicker solobarics. You can buy a pair for around $189ish and they will work well in a sealed box just above 1 cubic foot.
Old Aug 27, 2003 | 08:14 PM
jmax
The old style kicker solo's don't perform better than new speakers that sell from $100 - $150. But the box size quoted was for an old solo 12".
Old Aug 28, 2003 | 04:43 AM
filtor1's Avatar
Good catch. I wasn't thinking striaght. I just bought 4-12's for $170 a piece. I love ebay.
Old Aug 28, 2003 | 09:47 PM
krmaxima's Avatar
some thing cheap . also i need a 15 that only required 2.0 max volume space. this is because i have a box tha is like 1.3 vloume space
thanks
Old Aug 28, 2003 | 10:25 PM
jmax
If you only have 1.3 cubic feet you need a sub that only needs 1.05 - 1.15 cubic feet. Once you subtract sub displacement that's all you will have left. I would look into a different enclosure design or location. Or a smaller sub.
Old Aug 28, 2003 | 10:31 PM
krmaxima's Avatar
i used poly fill so i have about 1.2-1.3 total with the sub. but the sub i have right now need way more so its not hitting hard. so any subs out there that doesnt need a lot of space???? if not im going to change box into a 12 we will see
Old Aug 28, 2003 | 10:42 PM
jmax
To get the low end you need more power. But if you need more power than the voice coil can handle it will overheat. Other thing is that the smaller the box the less air there is to cool the subs voice coil. I think the Ed 15 is good down to 1.5 cubic feet. The Tumult would likely do well in car with a box that small. But neither of these fit the cheap requirement. You will have to make a compromise somewhere, especially if you want cheap. If you really wanted the bass that a 15 can provide you would compromise by useing a bigger box or designing a box that wraps around the curves of the trunk to get the needed volume. There are some really good 12 inch subs that can play lower and louder than most 15's sold a few years ago.
Old Aug 28, 2003 | 10:50 PM
krmaxima's Avatar
i think im just going to re do the box for a 12inch i never used fiber glass but doesnt seem hard
later
