LCD and DVD dont work anymore?
Old Sep 11, 2003 | 11:10 AM
94M@X's Avatar
Hello all
I am going to go crazy. I have the redmax 7" lcd and dvd player. It was working fine for a while until one day I changed the wiring for my headunit. It already has a dedicated power to battery, so I gave it a dedicated ground to try and help with a dimming problem I was having. anyhow after that the lcd and dvd no longer turned on? I tried changing all the ground back but that had no effect. I checked over several times here is how everything is wired:
LCD (microvision 7000bct) 3 Wires:
Red - constant
Orange - ignition
Black - ground
LCD had lighter adapter (spliced it):
Wire with white line - ignition
Plain black - ground
Headunit Alpine CDA 9813 (works fine but is getting power directly from battery)
I was thinking maybe a fuse is blown but checked all fuses in dash and they are fine. I've also checked to make sure that the wiring is secure.
Any suggestions
Old Sep 11, 2003 | 11:34 AM
PoLo's Avatar
2-Wheelin it...
have you checked the fuses by the battery
when i was doing my alarm, i blew that ignition fuse twice. that's what i get for dragging wire when i shouldn't.
Old Sep 11, 2003 | 11:54 AM
94M@X's Avatar
Is it an ignition fuse or radio fuse? If the ignition fuse was blown would the car still start?
Old Sep 12, 2003 | 04:17 AM
94M@X's Avatar
Help Please! It is killing me that everything is there and not working.
Old Sep 12, 2003 | 10:18 AM
94M@X's Avatar
Oh, just to add when I have the head unit on Aux (dvd player) I can hear the sound that buzzing type sound you get when a ground isn’t right and it gets louder as the rpm's go up. Might help determine a problem.
That only happens with aux selected. CD and Tuner are fine.
Old Sep 12, 2003 | 11:21 AM
PoLo's Avatar
2-Wheelin it...
rechecked your headunits ground?
if you tapped any of the ignition wires into ground accidently, you'l get a whole buncha wacky **** happening to you.
Old Sep 12, 2003 | 11:25 AM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
first off ground that sucker good. if not then you will get the humming. you can add a noise filter that may help you out. Check your acc. fuse also check power at the units with a 12v tester. if you have power then your ground is no good. check the ground continuity with a tester. I have a fluke works great. if all is well the only ting left is a problem with your unit.
Old Sep 13, 2003 | 12:35 AM
94M@X's Avatar
I am going to pick up a 12v tester.
Old Sep 13, 2003 | 08:00 PM
94M@X's Avatar
where can I get a switch for the lcd?
Old Sep 19, 2003 | 10:02 AM
94M@X's Avatar
Everything is working now !!!
I went out a bought a Auto-Ranging Tester from radis shack and all of my power sources were good. Strangely it turned out that the factory ground was bad. I regrounded to another location and everything is back up. I will take pics this weekend.
I also didnt have to switch the LCD. I only connected the power / ground and I am able to control the power with the remote control.
Thanks for the help!!
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
