Easy way to remove these screws?
Old Sep 13, 2003 | 10:17 AM
sanne's Avatar
I'm trying to take out the trunk carpeting and I need to know an easier way to take out the plastic screws that look like they can be taken out with a phillips screwdriver but cant. The only way I've been able to do so is by prying them out and literally ripping them apart almost. Also, what's an easy way to put them back in?
Old Sep 13, 2003 | 10:44 PM
nismos14's Avatar
§è~® f®ÈÄk
turn with a screwdriver but go at a little bit of an angle so they push against the lil retainers then they should come out
Old Sep 14, 2003 | 06:05 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
there is a tool they sell at home depot or wherever you go and it looks like a 2 legged fork.
Definetly a tool needed to be in a maxima modder tool set. Those things are everywhere
Old Sep 23, 2003 | 06:22 PM
MoCoMax's Avatar
Those are easy, but they take a little patience.
You need to loosen the screw head so it pulls out from the base that it sits in. If necessary, slide a thin regular head screwdriver or a knife under the screw head and lightly press out as you turn the screw head.
The screw should pop up, at which point you pull it, and the base, right out of the hole it's in. It sounds a lot harder than it really is.
Apr 16, 2020 05:15 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
