Hopefully a simple question about installing amp in '04
Old Sep 17, 2003 | 03:49 PM
chrisaust's Avatar
So I'm hoping the answer is as easy as I think it is. In the '04, the Bose system has amps for each individual speaker. So if I'm to add a sub and amp to replace the rear deck factory subs, I assume that the RCA lines that go into the factory amps, then into the factory subs, can literally be just unplugged from the amp and plugged into the amp I've purchased instead. Is that true? My amp has speaker level inputs as well as RCA. Also, do you guys suggest making use at all of the factory subs that are in the rear deck that will be unplugged, or just leave them as is, unused? Could the subs I bought (10" each) fit into those factory spots in the rear deck, or would it just be better to build a trunk box?
PH98I30
Jan 9, 2025 08:08 AM
melteye
May 16, 2016 12:02 AM
2k11ApexEvo
Mar 30, 2016 06:54 PM
Abdelrhman
Aug 17, 2015 12:16 PM
kirkhilles
Aug 8, 2015 10:53 AM
