Amp problems
Old Sep 18, 2003 | 08:40 PM
Badness's Avatar
Amp problems
i got a 4 ch American Legacy amp the amp powers on fine but i'm not gettin any sound from it what can be the problem?
any idea's?
Old Sep 18, 2003 | 09:25 PM
AscendantMax's Avatar
are the gains up?
Old Sep 18, 2003 | 09:44 PM
Badness's Avatar
Originally Posted by Fosgate Fan
are the gains up?
yeah the gain is all the way up
Old Sep 19, 2003 | 06:36 AM
Dohcser's Avatar
First turn the gains on the amp a little less than half way, this way if the amp does start working when you're playing around with it, the speakers will not pop, or the amp will not get damaged.
Did you verify you have a good signal being inputted into the amp?
Are you using all 4 channels?
If so you are probably running components or coax?
Also check my reply HERE to troubleshooting your amp. Look about half way down the page.
Old Sep 19, 2003 | 08:57 AM
Badness's Avatar
i use this amp for mids and high's the amp had no problem
one day i remove the ground but the system was completely off now when i attach the ground back to the car the amp came on but i got no sound from it i don't kno y? my bass amp worked completely fine though. now when i connect back the power wire and ground to the amp the amp power led isn't lighting up anymore.......
Old Sep 19, 2003 | 09:22 AM
Dohcser's Avatar
Time to break out the Multimeter, check all fuses and also check that you are getting voltage on the Remote turn-on lead and the power wire. Take the negative side of the multimeter and put it on the negative wire of the amp, then with your HU on take the positive and put in on the remote wire should be reading around 13.5V and also on the power wire. If you do not get any voltage, then take the negate lead of the multimeter and put in on the chassis ground and check for voltage again. Obviously this is hoping you have access to a multimeter. It could just be a blown fuse. Let me know.
Old Sep 19, 2003 | 11:28 AM
Badness's Avatar
no fuse's are blown ......
but when i remove the fuse from the amp i get a burnt smell.
Old Sep 19, 2003 | 12:33 PM
Kojiro_FtT's Avatar
Legacy is not known for quality. I wouldn't be surprised if it's just fried. Good luck trying to get them to cover it under warranty.
ivorton23
Sep 28, 2015 09:08 PM
popdedop
Sep 11, 2015 11:17 AM
