two components in car, question about setup
Old Sep 19, 2003 | 07:12 PM
meccanoble's Avatar
Sports Button FTW
Ok, right now i have Diamond Audio HEX components powered by a Kicker 200.2 watt amp. I have some Kicker components laying in my garage and a kicker 120.2 watt amp. Thinking of putting that setup in my car to have two components. I dont consider Kicker as high quality as Diamond Audio but u guys think its gonna sound ok having both setups in the car at once?
Also where do you recommend putting the mids at? I seen someone put the tweeters on the back pillars but not sure where to put the second pair of mids.
All feedback is appreciated.
Old Sep 19, 2003 | 07:36 PM
meccanoble's Avatar
Sports Button FTW
Quick Stats:
DIAMOND AUDIO
Cone: Kevlar/Nomex Sandwich
Tweeter Cone: Aluminum
Type: Component
Crossover Included: Yes
Drivers: Tweeter, Midbass
Drivers per Channel: 2
Specifications
Power(Watts): 20-170
Imped (ohms): 4
Sensitivity(dB SPL): 91 (w/2.83-V input @ 1 meter)
Freq,. Response: 42Hz-24Khz(±3dB)
Dimensions
Midrange
Mount Depth: 2-1/8"
Diameter: 6-1/2"
Tweeter
Dia: 1"
Mounting Type: Flush, Surface, Angle
KICKER
1" titanium dome tweeter
6-3/4" polygraphite woofer with titanium-deposit coating
treated foam surround
2-way 4,500 Hz crossover network (12 dB/octave high- and low-pass)
frequency response 33-21,000 Hz
recommended power range 6-75 watts RMS
peak power handling 150 watts
sensitivity 88 dB
top-mount depth 2-1/8"
1-year warranty
Quick difference comparison
Kicker vs Diamond Audio
Sensivitiy: 88 vs 91 db
Frquency response: 33khz-21khz vs 42khz-24khz
Peak handle: 150 vs 170
Old Sep 19, 2003 | 08:09 PM
NEW2DAGAME's Avatar
I have some tweeters on my back pillar too. I place a pair of 6X8's on a board and mounted then in the little ski shoot area that leads to the trunk. Its also being used as a port for my subs. It works great. I have my my bose rears hooked up to my radio too. Up front I have kicker resolution tweeters and coaxils in the doors.
Old Sep 20, 2003 | 04:32 AM
meccanoble's Avatar
Sports Button FTW
any pictures of your setup? not familiar wit this slope leading to trunk. PLease explain further
Old Sep 20, 2003 | 08:40 AM
NEW2DAGAME's Avatar
I'll get some pics. In the back seat you have the arm rest. In my car, the panel behind the arm rest leads directly to the trunk. I have the speakers mounted from the inside of the trunk facing in the cabin, with about a 2 in gap from the bottom of the board used as a port.
Old Sep 20, 2003 | 10:42 AM
meccanoble's Avatar
Sports Button FTW
dam that soudns too concealin and wit subs in cabin wont it over power the mids? so they are basically rendered useless?
Old Sep 20, 2003 | 10:58 AM
NEW2DAGAME's Avatar
Not to me, but thats subjective. It also depends on where you have your mids crossed at, plus its basically for rear fill. My fronts by far are my source of music.
Old Sep 20, 2003 | 01:24 PM
Dohcser's Avatar
well it depends on how you want your imaging! when you add too much in the rear you take away front imaging. if you are into SQ you should either take out rear speakers or have them in there for the rear passengers but they should be considerably lower than the fronts. As far as putting two sets of comps in the front this could help or hurt, depends on where and what angles you put them. Usually you would want to put MIDBASS on the kick panels and one set of good tweets also.
Lakersallday24
Jun 16, 2019 01:35 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
MikesChevelle
Aug 10, 2015 10:53 AM
cmpowell86
Aug 10, 2015 12:35 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
